Nfamous60 FCOTM Nov Submission
Name: SPC. Kennerly, James
Lives: El Paso, Texas
Car: 2009 SS Turbo Sedan (Rally Yellow / 6 of 15)
Car's Name: Sinister Six
ALOT OF PARTS ARE STILL IN BOXES BROUGHT DURING MY DEPLOYMENT.
Modifications Are:
Motor: ARP Head Studs, Amsoil 5w30, New GM Rod and Main Bearings, Hahn racecraft Intake, ZZP Intake cam with bigger fuel lobe, Wiseco Pistons, ZZP motor mount, New coils PWerks upgraded LPFP(700hp support).
Turbo: Hahn Racecraft IC, Hahn Racecraft Charge Piping, Brand new ZZP Charge Piping w/ Maf relocate, Precision Turbo 5857SP DBB T3 w/.63ar, Tial Type"Q" Blow Off Valve, Turbosmart 38mm Wastegate, Treadstone Titanium Heat Shield,
Transmission: Spec Stage 3+ Clutch, Clutch-masters Light Weight flywheel, Brand New GM Factory Flywheel, ZZP Trans mount, Th-motorsports Stainless Steel Clutch Line, ZZP Adjustable Clutch Rod.
Electronics: AEM Digital Boost gauge, AEM Digital Wideband Gauge, GM Performance MAP Sensor harness, GM Performance 3Bar Map Sensors, ZZP MAF Extension Harness, N2MB WOT Box & 2 Step Launch Control,
Exhaust: Hahn Exhaust, MPX Catless Downpipe, MPX electronic Cutout,
Brakes: PowerSlot Slotted Rotors Front & Rear, Brand New GM Factory Brake Pads, THmotorsports Stainless Steel Braided Lines.
Suspension: Powell Racing Hardcore Rear Sway Bar, Powerglide Endlinks.
Other: BuyHids Dashpod, Buyhids Reverse Hids, Buyhids Cup Holder lighs, Treadstone radiator hoses, Treadstone BPV block Off plate, Custom painted Valve Cover (Pwerks), ZZP dual Gauge Pillar
FUTURE MODS: ZZP 2.0 Gridled Block, ZZP Rods, ZZP ATI Damper, ZZP NBS, KW Variants 2, Treadstone Exhaust Manifold and Downpipe. ZZP Stage 2 Tranny.
Modifications Are:
