OneCOLDBIZL272's March FCOTM Submission
Old Feb 18, 2012 | 07:01 PM
OneCOLDBIZL272's Avatar
Car Info: 2005, Chevy, Cobalt, SS/sc
GOOD LUCK TO EVERYONE THIS MONTH...
Thanks to curt F-R(Zspeed) for helping me get this completed, this wouldn't of happen if it weren't for alot of his help. This car has alot of blood sweat the tears and money that went into it.... and thanks to all the vendors that helped along the way TTR, ZZP, OTTP, and many others. Note: This is not a shop car...working on my car and others is a hobby of mine.
A lot of stuff has just been done to the car in the last 6 months no new #'s @ the time being sorry in advance.
"WISCONSIN FIRST BUILT LSJ"
Exterior Modifications:
De-badged (All Badges Removed)
Custom Shorty Antenna
Switch Backs Led Corner Lights
Skyline Style Led Tail Lights (Functional Inners)
Custom Front Upper Grill
Painted Silver Brake Calipers
Painted Black Bow Tie
Carbon Fiber Outer Door Pillar
4th Generation Projector Head Lights
10K H.I.D.
21 LED Fog Lights
Led Reverse Lights
Led Plate Light
Led 3rd Brake Light
RKSports Ram Air Hood Carbon Fiber (Painted Silver With Black In Lay)
Evo 10 Front Bumper Mod Carbon Black
Painted Rear Defuser (Looks Similar To A 2.4 Rear Bumper)
Black Gm Addiction Aluminum Caps (Coolant, Washer Fliud, Brake Reservoir)
Dupli Color Rubber Under Coat (For Sound Deadening / Prevent Rust 1/8”Thick)
Custom Plates (Lil Vett)
Interior Modifications:
Steering Wheel Buttons Custom Blue Leds
Steering Wheel Center Cap Painted To Match Steering Wheel (Flat Black)
SS/TC Seats (Swapped Out Of My SS/TC Before Sold)
Custom Painted Dash Inserts (Hammered Metal Finish Stock Color)
Blue Led Module Kit For Dash Cluster
Three Pod Pillar With (Autometer Cobalt Series 30psi Boost Gauge/Water Temp/Oil Pressure)
Custom Dual Cluster Pod (Aem Wideband/Volt Meter)
Avic-D3 In-dash Dvd/Nav (With Powered IPod Cable)
GM Performance Floor Mats
GM Center Console Arm Rest
80mil Dynamat (Complete Interior,Complete Trunk)
Flip Style Key Fob
Suspension/Drive train/Brakes:
Custom Modified/Built F35 Transmission (Redline MT-90 Fluid)
SS/TC Solid Shift Bracket
SS/SC Updated Shifter Cables
SS/TC Throw Out Bearing
Spec Light Weight Flywheel (7.5lbs) (With ARP Flywheel Bolts)
Spec Stage 3+ Clutch
Hurst Short Throw Shifter
Solid Shifter Base Bushings
Turbo Tech Racing Trans Mount Polyurethane Bushings In Stock Mounts (Custom Shims For Tight Perfect Fit)
Turbo Tech Racing Upper Billet Polyurethane Engine Mount
Custom Solid Driver Motor Mount (Polyurethane)
Intense Stage 2 Axles (Cryo’d For Extended Strength After Bought)
Tenzo-R GT2 Lowering Springs (1.75" Front Drop 2.25" Rear Drop) (W/Drag Bags)
Adjustable Koni Sport Shocks (Front Struts / Rear Shock)
Intense Polyurethane Control Arm Bushings (Custom Shims)
Custom 5mm Wheel Spacers
Moog Ball Joints (With Grease Fittings)
Moog Tie Rods (With Grease Fittings)
Polyurethane Sway Bar Bushings
Bwoodyperformance End Links (3/4" Thick Over Stock 5/16")
ZZP Front Strut Bar (Powder Coated Black)
Turbo Tech Racing Rear Sway Bar (25.4mm)
OTTP FTP Stainless Braided Brake Lines
GM Performance Vain/Vented Rotors (Cryo’d)
Rolled Rear Fenders
F05 18x7.5 Flat Black Powder Coated Rims
NS-II Drag Radials (235/45/18R) (Slicks Track Day)
Performance Modifications:
Harrop 1320LSJ Supercharger (2.7 pulley)
Diamond Coated Forged Piston/Pin/Total Seal Rings 10:5.1 (Also Oversized that of stock 86mm CPR Is Roughly 11:1 With Milling Of Block/Head)
Custom Sleeved Block (Sleeves Are Cryo'd)
Built Bottom End
Custom Built Head Ported/Polished 7,600 Rev Limit Personal Pref.
Custom Balance Shafts Delete Kit (Deleted There Are No Balance Shafts At All)
ZZP Oil Cap Valve Cover Breather
Custom A/C Delete
Custom Cryo'd Oil Pump Gear
ARP Head Studs
ARP Main Studs
ARP Rod Hardware
SCE LSJ Copper Head Gasket
GM Stage 2 Belt
ZZP Adjustable Tensioner
Custom Ported & Polished Intake Manifold
ZZP Phenolic Intake Spacer
2.2 T-Stat House W/-AN Fittings
Gates Performance T-Stat
Alternator Rebuild (Lighter Pulley)
AIS Big Trunk Mount Meth/Injection Kit (Meth Comes On At 11lbs Of Boost 9gph 80%methonal/20%water Mix)
Custom 3" Intake ( K&N Filter)
LS4 Throttle Body (87mm)
Weight Reduction
Custom 3" Under Axle Exhaust System (No Clearance Issues W/Magnaflow Muffler)
Custom Exhaust Header
OTTP Second Gen Heat Exchanger (Aeroquip Hose & Fittings)
Meziere's Wp136S Aftercooler Pump (1200GPH) (Custom Mounted/Aeroquip -12AN)
Custom Dual Pass Endplate (With Aeroquip AN-Fittings)
HKS Oil Catch Can
Custom Oil Cooler System W/Front Mount (-10an Braided Steel Lines, Car Now Uses 8.5qt Of Oil)
Custom In-tank Dual Fuel Pumps
Custom Modified Fuel Sending Unit (In Tank)
Injector Dynamics 1600cc Injectors W/Harness (Running E85)
NGK BKR7E Spark Plugs
Custom Fuel Pump Re-wire Kit
Custom Fuel Retune Line With Fuel Labs Pressure Regulator)
Custom Braided Fuel Return Line (-6AN) With Fittings)
Custom Braided Fuel Feed Line (-6AN) With Fittings)
Custom Fuel Rail Adaptor (-6AN)
Dual Aeromotive Fuel Filters (800microns Each)
Custom Tune Hp/Tuners
Future Upgrades Or Parts In The Works:
Car Has LS4 Throttle Body, I Have A Second One That I'm Having Bored Over To 90mm 0r 92mm With New Butterfly.(3mm-5mm Larger)
Remote Mount Electric Water Pump
Custom Titanium Cat-back exhaust
Carbon Fiber Trunk W/Wing
Bigger Brakes
Convert Most If Not All Hubber Hose In Engine Bay Over To Braided Line
Custom Center Dash Air Vents Will Become 4 Mre Cobalt Series Gauges
Old Feb 18, 2012 | 07:11 PM
carstedt's Avatar
very nice...i used to see u out on hwy 100..hopefully we can giv em a run when im back after this deployment
Old Feb 18, 2012 | 07:14 PM
sjc0013's Avatar
Window Licker
Now that is a performance mods list! What sorta power are you cranking out?
Old Feb 18, 2012 | 07:21 PM
Yeah I use to live behind Ultimate Truck, that and I use to cruse a lot. I don't really do that on hwy 100 any more. You mostly see me out there from here and there thou cause I work in that area.
Old Feb 18, 2012 | 07:26 PM
carstedt's Avatar
ya i havent been out there much since 09 i jus used to see u here and there...but hopefully in may 0f 2013 when i get back ill see u around and giv em a run
Old Feb 18, 2012 | 07:27 PM
zrated89's Avatar
how about some real timeslips this time around
Old Feb 18, 2012 | 07:28 PM
Last time I was on a dyno I blew out my dif and snapped an axel. Since then a lot more time has been put into the car along with mods. Don't know the current number right now goal is to hit 400hp or over
Old Feb 18, 2012 | 07:32 PM
yeah Im still out there just dont drive the hwy, Last year I only put little over 5,000miles on the car. Sounds good best of luck in the current depolyment that your on.
Old Feb 18, 2012 | 07:34 PM
MastaShaKe_88's Avatar
any vids of the balt in action??
Old Feb 18, 2012 | 07:39 PM
yes and no. Their more sound clips that I took video with my iphone 4gs cause few people wanted to hear my exhaust. That it really, so no real video's of the car in action, use to have a few on my old LGVx8100 cell phone but, that puppy has long bite the dust. I will have more in the future I'm going to try to get a GoPro Hero 2.
Old Feb 18, 2012 | 07:42 PM
AaronJ's Avatar
That's a good looking car. You should come to a WI meet (if we can ever get one organized ) so that I can get a ride in this baby
Old Feb 18, 2012 | 07:48 PM
Thats because its hard for everyone to meet up at a set time with short notice. people have stuff going on, work conflicting schedule, or have families or just dont have the time. I use to do a lot of them but that was years ago. I also don't go far with the car, due to lack there of options for ethanol and methanol. And thank you for the comment
I know just about everyone in the wis thread
Old Feb 18, 2012 | 08:18 PM
AaronJ's Avatar
Originally Posted by OneCOLDBIZL272
Thats because its hard for everyone to meet up at a set time with short notice. people have stuff going on, work conflicting schedule, or have families or just dont have the time. I use to do a lot of them but that was years ago. I also don't go far with the car, due to lack there of options for E85 and methonal. And thank you for the comment
Except me lol
Yeah one of these days I hope we can plan something out more than just 3 days in advance
Old Feb 18, 2012 | 08:25 PM
Except me lol
Lol well I did say know pretty much everyone lol sorry Aaron. I hear ya.
Old Feb 22, 2012 | 02:26 AM
BlkWdoSS's Avatar
Hey do you know a Tim that owns a Monte Carlo SS Dale Earnhart JR edition? He recently moved to Texas, and then moved back up there. He said he lived down the block from "lil Vett" and thats you lol.
l8r,
PD
Old Feb 22, 2012 | 01:44 PM
ralliartist's Avatar
you blew out your diff and snapped an axle on the dyno? What did you do, launch it at 10,000rpms? WTF? I've never heard of anyone doing anything like that on a dyno before. You sure you weren't at the track?
Old Feb 22, 2012 | 04:12 PM
No it was on the dyno. My guess is because my trans had over 100,000miles. And I think the axel was on its way out the door prior to going on the dyno and it just happen to fail while on the dyno. It just was timing that they both happened at the same time. Both are fixed
Old Feb 22, 2012 | 04:14 PM
l8r,
PD
Yep I know tim lol he told me a week or two ago that he had gotten a ride in your car. Yeah he lived about 7 mins walking distance from my house.
Old Feb 22, 2012 | 05:01 PM
ebristol's Avatar
Welcome back Derek.
Its good to see the car back up and running.
Old Feb 22, 2012 | 05:47 PM
zrated89's Avatar
just like those "nice" fast times on your car. I wish you were local to me id run you in a heart beat
Old Feb 22, 2012 | 06:00 PM
strazdice's Avatar
Nice derek!
Old Feb 22, 2012 | 07:07 PM
Originally Posted by ebristol
Welcome back Derek.
Thanks Eric
Old Feb 22, 2012 | 07:09 PM
Originally Posted by strazdice
Nice derek!
Thanks mike
Old Feb 23, 2012 | 12:41 AM
whered you buy those rims? i want naow
Old Feb 23, 2012 | 12:50 AM
jvc06sc's Avatar
Looks good! Did the car ever run the high 11 low 12 for the quarter mile thread? I remember the thread but I never saw the result.
