Riceburner December FCOTM
Owner: Adam
2006 Cobalt SS/SC
Got it stock, non G85. Now it’s highly modded and LSD, 3 years later
Been in love with this car since day one. Been through many little issues along the way but thanks to everyone on here it is where it is now.
Over this last winter we tore it down and did a mild re-build and trans swap. It was a fun winter and now that the car is on the road again it’s better than ever! Feels great to have one of the few 300+ whp m62’s out there.
Tuned by Armcclure, made 302/270 on a dynojet
Best run on setup: 13.660 @ 106.42 mph. 2.2 60’ on street tires and no wot box usage.
Internals:
LSJION Ported & Polished Head
ZZP Stage 2 Blower Cams
Performance Autowerks 80# Valve Springs
New Valves, Retainers, etc
ARP Headstuds
Machined crankshaft for larger keyway
LevelZero Balance Shaft Delete Bushings
New timing set, ARP Timing Bolts
Boltons:
80# Injectors to run E85
ATI Superdamper (overdrive, makes pulley size act smaller)
Ported/polished intake Manifold
Ported/polished/plugged M62, 2.7” Pulley
ZZP 3” Intake
ZZP Longtube Header/Catted DP
ZZP 2.5” Resonated Catback
ZZP Magnetic Drain plug
Moroso Catch can ran from gutted/drilled valve cover
ZZP Machined Valve Cover
Cooling
Custom Dual Pass Endplate
ZZP Stealth heat exchanger
OTTP Stg1 front mount heat exchanger
e85? kinda?
Ported blower and mani helps a bit too
Drivetrain:
GMPP Clutch kit
Stock Flywheel
LNF Shift Bracket
ZZP Axles
Powell Trans Mounts
LSD trans with 15k miles
Suspension:
SSC Lowering Springs
Moog Front Sway Bar Endlinks
KYB Front Struts
Kyb Strut Mounts
Moog Front Tie Rod Ends
Moog Control Arm Bushings
Koni Rear Adjustable Struts
ZZP Front Strut Tower Brace, powdercoaded black
Unknown Brand Rear Swaybar
Wheels/Tires:
TC wheels powdercoated anthracite metallic
225/40/18 Nitto NT555 tires
5x110-5x110 1” hub adapters in front
1/2” spacers w/ arp extended studs in rear
Red anodized open ended lug nuts
Brakes:
R1 concepts slotted rotors
Hawk HPS pads
Red Calipers
Exterior:
Front Turbo SS Upper and Lower Grilles
Colodude18 retrofit K2 Motor Dual Taillights, smoked
Retrofit headlights by me, E55 Silver colormatch Shrouds, flat black housings, Mini H1, 8000K, Grabber Blue Demon Eyes Mod, Led turn signals
Windshield Banner Tint
20/35 Window Tints
Upper Evo Mod
Tint side markers/3rd brake light
Red Caliper Paint
C/F Bowtie
C/F License Plate frame
Shorty Antenna
Hide-a-plate
C/F SS inlays
‘Supercharged’ red badge on trunk
#working on a cf trunk!
Interior
Black on black ss/tc seats
Armrest
Redline Goods Armrest cover and shift boot
Front and Rear huskyliners floormats
RedlineGoods Alacantara steering wheel
Carbon fiber ‘ss’ steering wheel badge
Trunk huskyliner mat
Huskyliner flootmats
Map leds
Modified Gauge faces to glow whiter (by rains_crusaider)
White led swap on all button panels (by rains_crusaider)
Single pod steering wheel bezel
GMPP Pedalset
TWM Short Shifter with base bushings & cable clamp
Flat black painted dash trim
Factory Dome Light w/ LEDs
Dual Gauge Pod
Electronics:
Aeroforce Multigauge
Aem Eugo wideband
WOT BOX (LC + NLS)
Audio:
Pioneer AV-900BT Double Din w/gps & bluetooth
Rockford Fosgate Speakers (front & back)
Alpine Sub Amp
Polk Audio MM1040 Sub in modded stock sub box
Alpine amp mounted on back of rear seat
eww some of my pictures turned out really grainy i just realized
umm i have no idea actually; bought it from some member, its a chrome piece with a fakeish carbon fiber insert. sadly noone seems to make them anymore.
