Riceburner February FCOTM
Old Jan 23, 2015 | 03:29 PM
Owner: Adam
2006 Cobalt SS/SC
Got it stock, non G85. Now it’s highly modded and LSD, 3 years later
Been in love with this car since day one. Been through many little issues along the way but thanks to everyone on here it is where it is now.
Over this last winter we tore it down and did a mild re-build and trans swap. It was a fun winter and now that the car is on the road again it’s better than ever! Feels great to have one of the few 300+ whp m62’s out there.
Tuned by Armcclure, made 302/270 on a dynojet
Best run on setup: 13.660 @ 106.42 mph. 2.2 60’ on street tires and no wot box usage.
Internals:
LSJION Ported & Polished Head
ZZP Stage 2 Blower Cams
Performance Autowerks 80# Valve Springs
New Valves, Retainers, etc
ARP Headstuds
Machined crankshaft for larger keyway
LevelZero Balance Shaft Delete Bushings
New timing set, ARP Timing Bolts
Boltons:
80# Injectors to run E85
ATI Superdamper (overdrive, makes pulley size act smaller)
Ported/polished intake Manifold
Ported/polished/plugged M62, 2.7” Pulley
ZZP 3” Intake
ZZP Longtube Header/Catted DP
ZZP 2.5” Resonated Catback
ZZP Magnetic Drain plug
Moroso Catch can ran from gutted/drilled valve cover
ZZP Machined Valve Cover
Cooling
Custom Dual Pass Endplate
ZZP Stealth heat exchanger
OTTP Stg1 front mount heat exchanger
e85? kinda?
Ported blower and mani helps a bit too
ZZP Option B kit bled from intake mani
Drivetrain:
GMPP Clutch kit
Stock Flywheel
LNF Shift Bracket
ZZP Axles
Powell Trans Mounts
LSD trans with 15k miles
Zzp input and output seals
Suspension:
SSC Lowering Springs
Moog Front Sway Bar Endlinks
KYB Front Struts
Kyb Strut Mounts
Ottp steering rack spacers
Moog Front Tie Rod Ends
Moog Control Arm Bushings
Moog rear spring seats
Moog front swaybar bushings
Koni Rear Adjustable Struts
ZZP Front Strut Tower Brace, powdercoaded black
Unknown Brand Rear Swaybar
Wheels/Tires:
TC wheels powdercoated anthracite metallic
225/40/18 Nitto NT555 tires
5x110-5x110 1” hub adapters in front
1/2” spacers w/ arp extended studs in rear
Red anodized open ended lug nuts
Brakes:
R1 concepts slotted rotors
Hawk HPS pads
Red Calipers
Exterior:
Front Turbo SS Upper and Lower Grilles
Colodude18 retrofit K2 Motor Dual Taillights, smoked
Retrofit headlights by me, E55 Silver colormatch Shrouds, flat black housings, Mini H1, 8000K, Grabber Blue Demon Eyes Mod, Led turn signals
Windshield Banner Tint
20/35 Window Tints
Upper Evo Mod
Tint side markers/3rd brake light
Red Caliper Paint
C/F Bowtie
C/F License Plate frame
Shorty Antenna
Hide-a-plate
C/F SS inlays
‘Supercharged’ red badge on trunk
#working on a cf trunk!
Interior
Black on black ss/tc seats
Armrest
Redline Goods Armrest cover and shift boot
Front and Rear huskyliners floormats
RedlineGoods Alacantara steering wheel
Carbon fiber ‘ss’ steering wheel badge
Trunk huskyliner mat
Huskyliner flootmats
Map leds
Modified Gauge faces to glow whiter (by rains_crusaider)
White led swap on all button panels (by rains_crusaider)
Single pod steering wheel bezel
GMPP Pedalset
TWM Short Shifter with base bushings & cable clamp
Flat black painted dash trim
Factory Dome Light w/ LEDs
Dual Gauge Pod
Electronics:
Aeroforce Multigauge
Aem Eugo wideband
WOT BOX (LC + NLS)
Audio:
Pioneer AV-900BT Double Din w/gps & bluetooth
Rockford Fosgate Speakers (front & back)
Alpine Sub Amp
Polk Audio MM1040 Sub in modded stock sub box
Alpine amp mounted on back of rear seat
NEW:
Trunk gutted, rear seats, bar and belts out,
subwoofer, and etc ~135 lb weight reduction
to go on this spring!
TVS, and fueling mods...
carbon fiber trunk
Option B
GMPP Axles
new retros
Old Jan 23, 2015 | 03:42 PM
WVU_SS's Avatar
The only thing I miss about the m62 is that sound.
I've had a heck of a lot of fun seeing the progress you've made on that thing man.
If I remember to vote this month you've got my vote.
Old Jan 23, 2015 | 04:40 PM
BlackielawlessSS's Avatar
Much love for your SS rice
Old Jan 23, 2015 | 06:40 PM
Tsbbzm's Avatar
Jedi Master
Love the TC wheels.
Got my vote man
Old Jan 23, 2015 | 07:31 PM
Got to like those blue wheels
Old Jan 23, 2015 | 11:39 PM
Thanks dude preciate it, im gonna miss the m62 for sure but will do all i can to make the tvs scream like a 16 year old with a horsec***
Thanks everyone. Blue wheels are gone but i had no time this season to get good pics with the new wheels. I need a real camera this next season :
Old Jan 23, 2015 | 11:47 PM
Car still looks great rice!! You guys sure make it hard to pick the winner
Old Jan 24, 2015 | 05:20 PM
LNFTX's Avatar
I really like the color of those wheels rice are those Tommy P's old wheels or did you get them done I would really like that color on my black tc
Old Jan 24, 2015 | 06:29 PM
Thanks everyone!
These sre not tommys old wheels but i was going for that same antracite metallic color. These are a shade darker than what i wanted but they work nice. Color is kingsport by prismatic.
Old Jan 24, 2015 | 09:23 PM
06blackbalt's Avatar
Very nice! Borat voice
Old Jan 30, 2015 | 12:33 PM
BoostedBeaner's Avatar
This car is lame. Silver is the worst color on cobalts
Old Jan 30, 2015 | 05:13 PM
I know right, its right between the best colors black and white too lol
Old Feb 10, 2015 | 04:12 PM
Future SS Owner's Avatar
I love your interior! Even though you sold the double din
Old Feb 10, 2015 | 04:21 PM
07blackg5's Avatar
Slobodan Milošević
single din is more aerodynamic when you race anyway!
Old Feb 10, 2015 | 04:44 PM
Twoozofjuice's Avatar
Trunk gutted + rear seat/bar removal took off maybe 50 lbs on my car. 2920 with half a tank and full interior. 2850 with a bit over 1/4 of a tank and removal of those other things. Or what'd you plan for the 135+ lbs of WR
Old Feb 10, 2015 | 08:48 PM
i actually weighed everything lol. n2m there is actual weights posted about most of these things:
seatbelt bar: 8 lbs
trunk insulation/plastic panel where trunk latches into: 5 lbs
subwoofer (aftermarket installed into stock housing) - 19
amp for that sub - 8
rear huskyliners floormats - 3
rear huskyliner mat - 10
rear seats - 35
rear headrests, seatbelts, xm module - 10
26 - spare tire
insulation under rear seats - negligable but maybe 2 lbs
a/c consensor - 15 lbs
hood liner - 5
thats 146ish lbs (give or take 5-10 for sake of scale being off at low weights) that i can think of, another 20ish on the way if i isntall my carbon fiber trunk, and yet another 30+ if i get a 3.5lb battery. might be more that i forgot about too! of course i've added some stuff as well, fmhe, opt b, etc.
Old Feb 11, 2015 | 01:09 AM
Forgot I had already taken out spare and some of the trunk stuff before hand haha. And yeah no sub here lol. Good luck with the times man you should get them just need that driver mod and you would've been there lol
Old Feb 11, 2015 | 08:26 AM
seatbelts weigh more than i thought too lol
every bit counts
thanks brah.
Old Feb 11, 2015 | 08:46 AM
07blackg5's Avatar
Slobodan Milošević
I felt the same way when I pulled the rear seatbelts. Heavy as hell
Old Feb 11, 2015 | 10:20 AM
leather is heavy...
Old Feb 11, 2015 | 10:22 AM
07blackg5's Avatar
Slobodan Milošević
That's why I wear jeans opposed to my leather pants when I race
Old Feb 11, 2015 | 12:34 PM
leather is heavy thats why i switched to ss/tc fabric seats okay actually its cause the ss/sc seats are ugly as hell but still
riceburner
Oct 2, 2015 05:47 PM
hawkssoccer11
Sep 30, 2015 12:14 PM
