Staged07SS FCOTM Thread - October 2013
Location: NEPA Car Info: 2007 Cobalt SS Supercharged Stock Options: Sunroof, XM radio, 6 CD Changer, Side Air Bags, High Polished Aluminum Wheels No track or dyno numbers with the new set up yet unfortunately. But soon to come! Power = 294whp, 244wtq w/ race gas Modifications: Engine: - Eaton H62 Prototype "Hi Helix" Supercharger - GMR Stage 3 PCM/Calibration - GMR 76 mm Pulley - GMPP 42 lb/hr Injectors - GMPP Stage 2 Belt - Smoothflow 4-bolt Hub - COMP/ZZP S1 Cams - Supertech 75 lb Dual Valve Spring Kit - Production Donaldson Intake w/ Modified Airbox & K&N E-0777 Filter - Ported/Polished Throttle Body - 7500 rpm Rev Limiter Exhaust: - Ported GMPP Extrude Honed Manifold - ZZP 3" Downpipe w/ 200 Cell Spun Metal Cat - Corsa Touring 2.5" Catback Ignition: - NGK BKR7EIX 1-Step Colder Iridium Plugs Cooling: - GMR Dual Pass Endplate - GMR Option B Kit w/ ZZP Mounting Bracket - OTTP Front Mount Heat Exchanger Traction: - Powell Rotated Trans Mount - GMPP Rear Trans Mount Suspension: - MOOG Sway Bar End Links - MOOG Control Arm Bushings - Canuck Motorsports Springs - OTTP Rack Spacers Wheels, Tires, & Brakes: - Enkei EDR9, 18x7.5, +38mm Offset, Matte Black - Enkei A476-CAPCP Center Caps - Hankook Ventus V12 evo K110, 225 45 ZR18 95Y - Powerslot Rotors - Hawk Ceramic Pads Exterior: - DEPO Chrome/Smoked Headlight Housings - Sylvania Silverstar Ultra Bulbs - Trimbrite Carbon Fiber Wrap on B-Pillars - AVS Ventshades - MPx Shorty Antenna - SS/NA Lower Grille - Dupli Color Red Ceramic Calipers - Debadged rear Bowtie - Debadged GM Excellence Emblems Interior: - Aeroforce Interceptor - RedlineGoods Genuine Italian Leather Shifter & e-Brake Boots - NRG Black Carbon Fiber e-Brake Handle - GM Accessories Clutch/Brake Brushed Aluminum Pedals - CA Steering Column Gauge Pod Engine Compartment: - Cam Cover painted VHT Black Pearl - Coil Pack Cover painted Dupli Color Semi Gloss Black - Injector/Fuel Rail Cover painted Dupli Color Gloss Red Performance Data: - MAF: 38.71 lbs/min @ 7267-7500 RPM - Fuel Trims: +1.5 / -1.5 LTFT - Knock Retard: 0 KR - O2 B1S1 (mV): 815 mV @ 7411 RPM - Injector (pw): 20.9 ms @ 7500 RPM (yikes, :lol:) - Boost: 15.8 psi Note: All data taken on a chilly 35*F day. Future Modifications: - Install GMR S3 Nitrous Jumper Wires - Powell Rear Sway Bar - SS/TC or Koni Struts/Shocks She's come a long way in the 6 years I've owned her.... https://www.cobaltss.net/gallery/fil...03098738_o.jpg Panoramic shot: https://www.cobaltss.net/gallery/fil...91601831_o.jpg Side view: https://www.cobaltss.net/gallery/fil.../3/5/8/041.jpg Rear/side shot: https://www.cobaltss.net/gallery/fil.../8/_233510.jpg https://www.cobaltss.net/gallery/fil...5/8/_88197.jpg What makes her go: https://www.cobaltss.net/gallery/fil.../8/_788581.jpg https://www.cobaltss.net/gallery/fil.../8/_478843.jpg Interior: https://www.cobaltss.net/gallery/fil.../8/_122420.jpg The H62: https://www.cobaltss.net/gallery/fil..._3924156_n.jpg |
oh, hi helix! :bye:
(Post 7162070)
oh, hi helix! :bye:
well yea your car is still sweet. it's an all-around kinda car.
(Post 7162087)
Me gusta
Originally Posted by Sox-Fan
(Post 7162100)
Me gusta
Love that Z06 man!! |
Thanks Jeff. Don't let me forget to vote this month!
Well, I know who just got my vote this month! lol
(Post 7162123)
Originally Posted by Scythe_Snake
(Post 7162126)
So damn clean. You know you got my vote :twothumbs
(Post 7162160)
I'm going to try and snap a few more shots today or tomorrow. The leaves are just starting to change. |
I was just thinkng that, Jeff needs some more sexy pics lol
Car looks great. As always.
130.6 % Better not run nitrous past 7k lol |
Originally Posted by southal cobalt
(Post 7162214)
130.6 % Better not run nitrous past 7k lol When I run nitrous the limiter will be turned back down to 7k :) |
yep. my vote has now been spoken for. another car I love. between yours and bluelightnings.
Clean as always.;)
Ill trade you superchargers.. |
I want blue's lol
True
TVS=:#one: |
(Post 7162270)
Originally Posted by Tsbbzm
(Post 7162271)
Clean as always.;)
Ill trade you superchargers.. ;) |
Very clean. Where did the NRG E-brake handle come from?
niiiiice ride!!!
(Post 7162764)
Originally Posted by tazmanian devil
(Post 7162788)
niiiiice ride!!!
Additional exterior photos at different angles will be added today.
Keep an eye out for them guys :) |
New updated photos added.
Check em out guys :) |
