Forced Induction Turbos/Superchargers
2.2 turbo questions
Old May 11, 2010 | 05:07 PM
MillaTyme's Avatar
2.2 turbo questions
im looking at the zzp stage 2 turbo kit
https://www.zzperformance.com/cobalt...=922&catid=143
ok so ive done a lot of reading but i still have some questions, some of which are probably stupid but here goes...
do i have to get anything/do anything different since its a 2.2 instead of a 2.4?
is a turbo manifold considered a "header"?
should i get a 3" catback or a 2.5"?
what internals do i need to upgrade? (i think its cams and rods...)
if you can answer any of these questions it would help a bunch
Old May 11, 2010 | 06:04 PM
usdm08's Avatar
buddy of mines has a 2.2 on boost and hes making about 302 to the wheels on a stock motor and car has been running now for about 2 years with no problem
go with 3in exhaust if your going boost
Old May 11, 2010 | 08:55 PM
MillaTyme's Avatar
damn dude! non-forged rods right?
bumpity
Old May 11, 2010 | 08:58 PM
EcoTecDriver's Avatar
what psi is he running?
Old May 11, 2010 | 09:00 PM
Maupin SS/SC's Avatar
302 on the stock internals.......is he manual or auto aswell
Old May 11, 2010 | 09:13 PM
redcobalt07's Avatar
yeah 300hp on a stock internaled 2.2 and stock clutch isn't happening
Old May 11, 2010 | 09:15 PM
that was my thought exactly
Old May 11, 2010 | 09:22 PM
even for an auto that is pushing the auto transmission threshold
Old May 11, 2010 | 09:29 PM
MillaTyme's Avatar
so do you guys think ill have to upgrade the internals?
Old May 11, 2010 | 09:34 PM
ml2242's Avatar
for 300whp... yes
Old May 11, 2010 | 09:36 PM
after 250hp i'[d upgrade the internals
MillaTyme's Avatar
id be at about 250hp according to zzp, so maybe 225 whp
edit: upgrade what parts then? just rods?
Old May 11, 2010 | 09:38 PM
yeah 250 crank cause its the rods that are gonna break first
Old May 11, 2010 | 09:40 PM
MillaTyme's Avatar
any idea who carries em?
Old May 11, 2010 | 09:41 PM
turbotechracing.com
Old May 11, 2010 | 09:46 PM
MillaTyme's Avatar
aight thanks =)
still need some questions answered. thanks in advance!
Old May 11, 2010 | 10:04 PM
Boosted_Cobalt09's Avatar
i would stick with a 2.5" catback since you wont be boosting a whole lot and your not making a ***** loud of power. a turbo exhaust manifold is what your thinking is a header. theres a few things needed differently. spankeys monkey did a 2.5 so check his build thread out. as far as internals rods and pistons are a must
Old May 11, 2010 | 10:13 PM
MillaTyme's Avatar
i heard its >250hp you want a 2.5" so id be right on the border =/
Old May 12, 2010 | 03:01 PM
MillaTyme's Avatar
would these rods work? theyre from the LSJ
http://www.crateenginedepot.com/stor...P2390C131.aspx
Old May 12, 2010 | 03:21 PM
SCcobaltSS's Avatar
I believe the LSJ wrist pin is larger than the 2.2's.
I have a stock set sitting around if you need some.
Old May 12, 2010 | 03:22 PM
MillaTyme's Avatar
i thought so too =/
damn so im gonna have to pay like 1300 for rods and pistons. ghey
Old May 12, 2010 | 03:24 PM
SCcobaltSS's Avatar
I dont see why you cant press something in to make them fit your wrist pin. Not sure how this would work. 1300? What pistons/rods you wanna go with? Eagle makes rods for your car I thought. Eagle is cheaper than many other companies.
Old May 12, 2010 | 03:26 PM
Zdeuce4's Avatar
stenguyen1 on here has around 260whp 2.2 s/cd
u should be fine around that area with a solid tune.
Old May 12, 2010 | 03:29 PM
MillaTyme's Avatar
TTR has rods for like 900 and the pistons are about 400. ill look into those eagles though
yeah i was thinking about leaving the stock stuff but i dont want that fear that i will blow my motor and i just want that safety blanket since id be right at the border
Old May 12, 2010 | 03:39 PM
SCcobaltSS's Avatar
400 for the pistons and 330 for the eagle rods but IDK how good eagle rods are.
