2.8 pulley help!
you need a pulley puller.
you would need a tune as well.
I recommend getting the pulley and pulley puller from here:
http://www.smoothflowpulleys.com
or you can find everything you will need here:
http://www.ottperformance.com/
They provide a tune with it and everyone seems to have good luck with it. You may want to consider some other mods before you do a stage kit such as exhaust and a larger heat exchanger.
Hey i got a ? for you..If you have the stage 2 belt already, and wanna go smaller pulley like a 2.7, would the larger tensioner pulley work or does it have to be the adjustable tensior from zzp?
well there is currentyl nothing done to it but i have have ordered is a megan racing cat back exhaust drift style injen CAI and i was gonna do the pulleys.
well there is currently nothing done to it but i have have ordered is a megan racing cat back exhaust drift style injen CAI and i was gonna do the pulleys.
Last edited by vince07Cobaltss/sc; Feb 21, 2009 at 09:56 PM. Reason: Automerged Doublepost
Last edited by Black SS/SC 06; Feb 21, 2009 at 09:58 PM. Reason: Automerged Doublepost
i know i am gonna like it. and one more question for ya cause you seem to know alot about this stuff with the stage 1 KIT when i go to order it it says the:
PCM Core Charge: and it says email me a tune file or ill send my pcm in first
AND
Remove Torque Management: yes or no?
AND
AND
AND
Most people remove the torque management and do a 7,000 RPM redline.
You have to get a case relearn done and a security relearn done after the install as well.
