20g Feed/Return
Okay I've searched all over and yet to find a real answer. For those of you running the 20g what is the size of the oil feed oil return and water banjo bolts ? did you use stock lines with different bolts ? make lines ? I happened across one and will be putting it all together shortly
Thanks in advance -Brad |
Water ones are definitely m14x1.5
Originally Posted by blueLNFftw
(Post 7608055)
Cool so that should mean it is standard mitsu sizes M10x1.25 Oil and M14x1.5 Water I will update monday or tuesday |
anyone know the size of the feed/return on the block for oil and water ?
If you wait until I get back to ohio, I have every single spec to make AN lines for a 20g on a LNF.
I had to have a custom fitting made tho... |
Originally Posted by bflee
(Post 7608131)
The one on the front of the head with the barbed bolt going through it is m14x1.5mm I used this for my oil drain and bought the -10an block fitting from treadstone. Bolt spacing on the 20g is 38mm and standard is 40 or 50. http://pages.ebay.com/link/?nav=item...d=301940140863 |
Thanks, yeah just ordered the fitting for the drain, have a bunch of -6an line, I guess I need to order some -10 also, what size line did you use for coolant ?
About to just dump it and buy a s series lol
(Post 7609194)
-10AN for the oil drain -6AN for the coolant feed & return
(Post 7609205)
(Post 7609257)
-4AN for the oil feed
-10AN for the oil drain -6AN for the coolant feed & return Like, the Saturn S-series? Just dont! |
Sorry ignore the pm i was trying to be quick at work lol.
So did you use the banjo to -an kits on the block to make them all -an lines ? |
No.
I bought the fittings individually. You need a 1/2NPT to 6an. This goes on the t stat housing. You need a m14x1.5 to 6an banjo fitting. This goes on the front of the head. You will only use the banjo and not the bolt. You use the stock bolt that goes to the coolant tank still. |
Gotcha, that'll work since i have -6 line already, then I guess oil is the same way using the banjo on stock bolt and -4an the feed.
(Post 7609348)
I used fittings though. Only banjo I used was the one on the head. |
(Post 7609349)
You can I guess.
I listed that two posts up.
(Post 7609388)
I'll pull it all out and snap a pic as well.
Got the right flange on the way and ordered the treadstone -10an to stock drain. 1/2npt to 6an on coolant side. This is amazing with the whole motor out lol
