Boosted L61 2.2L Completed!
My camera died so I do not have the latest pics, but these are from the install!
http://**************/viewtopic.php?p=14083#14083
so you had the same problem as me with the 5th injector spraying fuel on start up. They sent me a new one and it did the same thing again, now i have to unplug the 5th injector start the car and plug it back in. Need my multi meter to figure this on out.
2.2ionjentzsch if you find out your problem with the 5th injector let me know so i can get rid of the gay problem
throwing idea's out there? When did it start...etc
no I had the 5th injector go bad and after that it has never been the same again.
Update:
Finally got to run her under some real boost!
Internal wastegate set for 7.5 and boost controller as well.
Spools up nicely and spikes to about 8psi then levels back out to 7.5ish.
Need to do a little tuning as it runs way to rich when I do a 3rd gear pull and boost is around 3-5. It drops hard to 10.0:1 AFR!
Other then that, she runs great.
More to come.
More to come.
yeah it came along with the kit i bought from LewiSS.
it has a tune on it for the 2.4 he tuned it on. i think its actually gong to work better on my 07 because of all the changes they made to the 2.2
Just order the Garrett Turbo kit for $3,194.00 total
they were having a sell so i decided to buy one after many months of saving. i got it off turbo-kits.com. the kit is the one with tuning, the injectors, and the others
