Forced Induction Turbos/Superchargers
custom 2.2 air to air fmic help
Old Mar 20, 2012 | 09:21 PM
rcarr0327's Avatar
Hey everyone. I have the zzp stage 2 turbo kit and i want to convert to air to air. just asking for any recommendations on piping kits or sizes for anything.
im think 2.5" piping with a 27x6x25 fmic or something like that. reason i want to get 6" tall is because im weary about fitting it behind my bumper cuz i had problems fitting the heat exchanger.
probably going to run a 3" short ram maybe cai if i feel up to it.
mounted my MAP as close to throttle body as possible with the BOV on the cold side somewhere before the MAP. Any suggestions?! Thanks!
Old Mar 20, 2012 | 10:34 PM
07cobaltguy's Avatar
I did 2.5" piping. I forget the dimensions on the core. If you shoot me a PM I can get some pics and dimensions for you.
Old Mar 21, 2012 | 12:40 AM
rcarr0327's Avatar
pm'd. anyone else?
Old Mar 21, 2012 | 12:53 AM
06_ion2's Avatar
I fit a 28X7X2.5 behind mine but im also an ion. I have 2.5 piping.
I ran my BOV on the hot side and my map on my intake mani. My MAF is located on the cold side where the pipe goes up and has a full 6in of strait pipe before the maf so it registers air correctly
Old Mar 21, 2012 | 01:30 AM
Brags's Avatar
Im running 24"x8"x3.5" with 2.75" piping, pics to give ideas
recirculated:
with regular tial Q:
intercooler:
Old Mar 21, 2012 | 09:51 AM
rcarr0327's Avatar
o damn those werks pipes are sick lol. i have an idea of what im doing for the top area but how does the piping look attaching to the intercooler so i know what bends and stuff to get
Old Mar 21, 2012 | 10:43 AM
Brags's Avatar
It's actually coming home this weekend. Send me a pm if you would rather see in person.
Old Mar 21, 2012 | 11:26 AM
Mine is 28x9.25x2.75. I would go with 7" rather than the 9" i have a rk sport front lip and the nubs on the bottom of the IC are flush with the bottom of the Lip and thats a big lip so id say 7" or 6" behind a stock bumper.
Old Mar 21, 2012 | 11:29 AM
ItalianJoe1's Avatar
You can also use an LNF stock I/C, as it bolts right up to the factory bumper and stuff. I did that on DFZ24's car when we switched his ZZP kit over to air-air.
Old Mar 21, 2012 | 11:58 AM
or that^^
Old Mar 21, 2012 | 03:00 PM
rcarr0327's Avatar
Sweet brags ill let u know. LNF fits well?
Old Mar 21, 2012 | 03:07 PM
BlackCobalt707's Avatar
intercooler i used. it had 2 mounting screws on top and 2 on the bottom. for the bottom, i used a long piece of flat metal with holes i got from home depot and i cut it short enough to mount from the intercooler to the car and the top, i had brackets i used to mount it to the bumper support
and installed. please ignore how crapily i cut out my grill...i literally used a hot knife to do it lol. took a butter knife, put it on the stove for a few minutes and melted out the grill lol
Old Mar 23, 2012 | 02:34 PM
rcarr0327's Avatar
didnt u have to mount that like behind the actual bumper so half of it was covered though? i want to mount it right underneath the bumper
Old Mar 23, 2012 | 05:42 PM
06_ion2's Avatar
thats the only place it really fit.
Old Mar 23, 2012 | 11:12 PM
rcarr0327's Avatar
well ya behind the bumper cover but i mean hanging the fmic behind steel bumper and attached on the top and have it hang down. ill try and get pictures.
edit:
like this, i dont want that much of the intercooler not getting airflow behind the beam, i want to hang it under the beam
Old Mar 24, 2012 | 02:01 AM
06_ion2's Avatar
the majority of warm spots will be on the lower half anyways, it shouldnt matter that much.
Old Mar 26, 2012 | 04:04 PM
rcarr0327's Avatar
about to order these, what do you think? anything else i need? ordering flanges for MAP and BOV later on.
2.5" TURBO INTERCOOLER ALUMINUM PIPING KIT+BLACK HOSES | eBay
Universal Front Mount Bar&Plate Intercooler 27x6x2.5 | eBay
for TB
Black 2.5" to 2.75" 90 Degree Silicone Elbow Reducer Coupler New Silicon Turbo | eBay
edit:
Also what size reducer should i get for the hot side to intercooler piping. 2" to 2.5"?
Old Mar 27, 2012 | 10:53 PM
noorj's Avatar
i would say dont cheap out on the intercooler, you can get ebay piping but a shitty core is just gonna raise iats, be harder on your engine and make less power
Old Mar 28, 2012 | 01:37 AM
rcarr0327's Avatar
well its not necessarily "ebay" its technically CXracing but from their ebay distribution channel. not much other places to get a 2.2 core without spending loads :/
Old Apr 5, 2012 | 10:55 PM
rcarr0327's Avatar
hey guys im having trouble fitting some pipes do to AC lines and other b.s. anyway to help get around the lower part of the engine bay to connect it to the fmic?
this is where im having troubles
Old Apr 5, 2012 | 11:58 PM
Brags's Avatar
Ill call you this weekend and you can check out my set up for ideas
Old Apr 6, 2012 | 12:29 AM
The passenger side, I usually just bend the a/c lines around enough to pass a coupler through them. Not a big deal.
The drivers side usually has enough room as is, you want to turn in, then towards the middle of the car, then up to wherever you are going. Use some combination of tubing bends and 90 degree hoses to get there.
Old Apr 9, 2012 | 10:11 AM
rcarr0327's Avatar
i got it, yea i just pushed the AC lines a smidge to get a 90 coupler in there and ran a pipe to a 90 to my intake. the driver side was easy after i slept away the frustrations from the night before. just waiting on a buddy to tig in the map and bov bungs
brags, one day i will see your car lol!
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
