Diy: Meth inj.
Diy: Meth inj.
i was wondering if anyone has kinda made there own meth kit. as in got a pump and bought lines from home depot or something. and if so what kinda *(jet) did u use. would a nitrous jet work if it was a low shot and if so what size is rec. or could u just re route ur washer fluid line with a fitting on the end and use it that way just interested. thanks ronnie
Nitrous jets will work but are not ideal. The nozzles we use will produce almost 1/2 the size in microns of water droplet. Another plus with buying a kit is you get a warrenty. And if you try to bit a pieace a kit together your probably not going to save very much.
