Hahn Turbo?
Hahn Turbo?
Im interested in the Hahn turbo kit, but not sure what kind of numbers to expect? Also is it more reliable then the SC on the car? I live in Toronto,so,not having crazy trq off the go is a good thing for colder weather, and having the top end my car is missing,also intrigues me. Any thoughts or info would be appreciated.
It is a very good complete kit but if you have the know how and mechanical skills you are better off piecing a kit together yourself. You also might want to take a look at some of the kits that ZZP is putting out. I believe with the S20G turbo that comes with the hahn kit you can expect somewhere in the low to mid 300 whp area depending on boost levels. I'm running 21-22 psi on a garrett 50 trim and traction is very limited at times even in 3rd gear.
I love my hahn kit...
ZZP has nice kits too....
I can only speak for hahn i have there kit im at 305 whp on stock spring in the turbo and thats 15psi ill know more this spring when i turn the boost up im thinking around 400whp
