Forced Induction Turbos/Superchargers
i need help
Old Jan 26, 2008 | 08:04 PM
slaminit1692's Avatar
i need help
i have a 07 ss/sc and this moring i got in it to got ride and when i was out i notice it was only pushing 4psi and it was very slow does ne 1 know wat this can be caused from??
Old Jan 26, 2008 | 08:06 PM
NJHK's Avatar
Bypass Valve possibly.
You need to do some more diagnostics because "only getting 4 psi" is kind of vague.
Are you modified or stock?
Old Jan 26, 2008 | 08:13 PM
its all stock other than a exhust
Old Jan 26, 2008 | 08:16 PM
NJHK's Avatar
Being that your supercharger spins at the same speed every time, I'm more inclined that it's a bypass valve issue or you have a leak in other locations.
Take it to your dealer.
Old Jan 26, 2008 | 08:17 PM
i am i was seeing if it had happend to n e 1 esle b/c the delaer is close till monday
Old Jan 26, 2008 | 08:21 PM
NJHK's Avatar
ah i c.
well you have my diagnosis
thanks
Old Jan 26, 2008 | 08:25 PM
NJHK's Avatar
You're welcome
Old Jan 26, 2008 | 08:38 PM
mike25's Avatar
from everything iv ever heard its more than likely your bypass valve
Old Jan 27, 2008 | 12:03 AM
is there n e way that i could check it or would the dealer have to
Old Jan 27, 2008 | 12:31 AM
FacelessKhaos's Avatar
pop the hood...start the engine...have somebody rev and you check for leaks...listen for hissing, or use a spray bottle full of mild soapy water and spray it on the hoses....if it bubbles or if you hear it...then problem solved...
or if it is the diaphragm inside then you should hear it just dumping air....
Old Jan 27, 2008 | 12:49 AM
negative nothing leaking
