Forced Induction Turbos/Superchargers
Looking for stockish turbo suggestion
Old Nov 24, 2017 | 05:41 PM
TroyK's Avatar
I seem to be blow blue smoke out the exhaust. I pulled the plugs & the porcelain looks white, so I guess I got a bad seal on the exhaust side of the turbo. I'm at 189k miles.
My current setup is a smallest aftermarket IC, DP & hi flow cat, cold air & hp tuners to 24-26psi. I still have stock IC pipes. 276hp/315tq at the dyno.
I'm just looking for 1 step up from stock, as I've had problems w trans bearings going out in the past, because it wont take my abuse. I've returned the tune below 3k to be back at stage1 to prevent my problems with the trans, but at 3.5k & above I have full power.
I'm looking for a little better spooling than stock & a little better power, to makeup for the blow by of an old motor. I'm looking at the PTE upgrade turbo, but PTE don't seem to be very popular here, so what do you guy recommend? Price is no object. Also, I am having a GM dealership do the work, so I need to keep the turbo stock looking to them, so they don't get confused. They just learned to tie their shoes last week, you know.
Old Nov 24, 2017 | 05:51 PM
Kobraa's Avatar
If youre looking for a slight upgrade, your best bet for factory bolt in is a ko4r. Its just our factory turbo with upgraded internals. or a z54 for zzp, but that quite a bit bigger upgrade, but it does bolt in same as factory.
Old Nov 24, 2017 | 06:32 PM
TroyK's Avatar
Well my car is going into the dealership Monday & it is my only car, so I will be driving a rental. When I look at turbobay's website, they say it takes weeks to make one. The zzp54, will it need the heat shields removed to fit or I guess how tight is the fit is the question?
Old Nov 24, 2017 | 09:22 PM
double clutch's Avatar
k04r is a waste. The dont last nearly as long as they should. go with the z54. You will have to remove the heat shields for it to fit, but its an easy install. Keep the boost down if you dont want a crazy amount of power. Then you can turn it up when you get the mod bug again.
Old Nov 26, 2017 | 06:43 PM
Tdubbs's Avatar
I'll second the Z54(I have one). It does spool slower than a stock k04, but not enough that I ever cared, since it pulls like a freight train anyway
Old Nov 27, 2017 | 06:02 AM
63 Nova SS's Avatar
If you had more time to wait, with money being no object, and wanting fast spool, the smallest efr turbo is the best, 6258. But you would have to build it to fit.
