Forced Induction Turbos/Superchargers
lsj turbo garrett gt35
Old Oct 24, 2012 | 07:49 PM
steve1213's Avatar
anyone can tell me a gt35 garrett .63 a/r when is make full spool at 15-20 psi on lsj ?
and a garrett gt35= wich turbo in precision?
Old Oct 25, 2012 | 02:27 PM
busa4's Avatar
i had a gt3582 and it spooled around 4500rpm. the smaller exhaust housing on the gt3563 should spool up around 3500rpm
Old Oct 25, 2012 | 07:54 PM
steve1213's Avatar
what is your max psi you have at 4500rpm?
Old Oct 25, 2012 | 08:11 PM
BLAZIN07SS's Avatar
I'm too JDM for you
What are your power goals first of all. Obviously not much on only 15-20psi. A 35r is going to be laggy for no reason. There are a lot of turbos out there. Pick one to match your goals
Old Oct 25, 2012 | 08:38 PM
steve1213's Avatar
first year i would make build and run to low boost maybe 10-15 psi and second year i would forge my block and go with 20-25 psi i would hit 400 whp i think is feasible?
Old Oct 25, 2012 | 08:55 PM
BLAZIN07SS's Avatar
I'm too JDM for you
You can hit 400whp on stock motor. 10-15 psi on an aftermarket turbo setup is worthless to be honest
Old Oct 28, 2012 | 02:27 AM
Nfamous60's Avatar
^^^ this
Old Oct 28, 2012 | 05:25 AM
06blackg85ss's Avatar
x15
gt3071 (.63) should net you @400whp at 21psi-ish depending on the tune little laggy out of boost down low, full spool @3200
gt3076 (.63 exhaust housing) should spool up @3500-3700 rpm full boost and make 400whp+ same boost
60-1 (.63) 400+whp @21 psi full boost 4200rpm ish
5857 438whp @22 psi full boost @3500rpm
6262 .63 a/r 500+whp 25psi full boost @4000rpm
5557 .63 a/r 400+whp 25psi full boost @3200rpm
that's just the few I've tested so far, all on stock motors
6262 car w/ zzp stage II cams (no dybo stock motor, 27psi was outrunning a supercharged c5 on e85)
http://www.youtube.com/watch?v=q45sBRxaDgE
same car with 5857 (stock cams) 438whp
http://www.youtube.com/watch?v=Xx7memhzX-I
same car with 3076 (stock cams) 420whp
http://www.youtube.com/watch?v=yuzbc1WCSmI
05 lsj (different car) 3071 stock motor 396whp @20psi
http://www.youtube.com/watch?v=cD8_fyu76_0
06 lsj 60-1 stock motor 444whp @23psi
http://www.youtube.com/watch?v=gHiJk...feature=relmfu
5557 car (only 17 psi due to leaking coolant and other issues with motor) it's the silver car in there, sorry for the long ass video didn't feel like editing (start @4:21) 317whp @17 psi bad boost controller so stopped at that
http://www.youtube.com/watch?v=u0A5Pmr8FWQ
60-1 built motor (minus sleeve doh) 17.5 psi 438whp
http://www.youtube.com/watch?v=iFI3K...feature=relmfu
Old Oct 28, 2012 | 10:25 AM
steve1213's Avatar
so its safe 400whp for stock motor? cause mine have 170 000 kilo i think is alot for put 400-450 whp in ?
Old Oct 28, 2012 | 10:30 AM
as long as it wasn't mistreated (i.e. proper oil change intervals) milage really doesn't mean much on newer motors.
tune conservative and it'll live. infe's car has been over 400whp for 2 years and @500+whp for over a year stock motor and he just pulled it apart over the weekend (no reason just wants more power) and it looked new internally, bearings were fine, crosshatches still in cylinder walls etc. granted he's under 50k miles but it more than likely would have lived for a while
Old Oct 28, 2012 | 10:35 AM
kxrida2000's Avatar
how many trannys has he gone through in 2 years?
Old Oct 28, 2012 | 11:58 AM
2 blown, had swapped out the original non lsd trans since the car basically didn't go anywhere lol. but it wasn't blown
Old Oct 28, 2012 | 12:02 PM
kxrida2000's Avatar
thats actually not as bad as i expected haha
Old Oct 28, 2012 | 01:21 PM
Nfamous60's Avatar
I vote 5857 lol because i have one. for 400whp i would say get the ZZP S252et turbo and you should be good. Nice low end response no point in such a big turbo if your goals are not that big im not sure but i think the BNR will net you that as well and those are priced very gud as well. Hahn makes a Super 20G that bolts up as well that could make you over 400 but they use old turbo tech from what i heard do not quote me on that.
Old Oct 28, 2012 | 03:06 PM
steve1213's Avatar
if i buy one news you think im better to get 5857 or 5858? and for have full spool at 3500 rpm i presume is a .63 a/r i need and not .82?
Old Oct 28, 2012 | 03:34 PM
.63 especially if you're not looking into making huge power (I"m talking 500+whp)
.82 you'll make more up top, but sacrafice a little spool time
Old Jan 14, 2013 | 12:10 PM
c130aviator's Avatar
There is s lot of great info in here!
Old Jan 15, 2013 | 10:40 AM
Dezod's Avatar
I would have to agree. It's a 2.0L. Ideally I would like to see a GT28RS or a GT3071 at most.
Depends on tuning to be quite honest.
I personally always opt for the higher A/R.
Old Jan 18, 2013 | 06:37 PM
shawnrandolph's Avatar
yeah the gt35 is quite large for the 2.0l
i will be going the precision 58mm for my lsj. A 252et is a great turbo for 2.0l also, I just didnt want to use a bullseye turbo.
Old Jan 18, 2013 | 08:47 PM
there are hahn videos of a cobalt ss on youtube making 440 whp on the gt35 but i feel its too much lag for the small 2.0. I am going to go with a GTX3076 with a small ar .63, right now my 20g is plenty, but in time... and still make 500 hp compared to the gt35's 440 on our car.
Look into the gtx turbos, they were released only in the past 2/3 years.
Old Jan 18, 2013 | 08:52 PM
BLAZIN07SS's Avatar
I'm too JDM for you
don't even pay attention to that gt35r video. that engine had 8:1 compression and made 290lbft of torque to go along with that 440whp bad engine build with not enough boost
Old Jan 18, 2013 | 09:23 PM
it did seem like there was something wrong there, tuning?
Old Jan 18, 2013 | 09:35 PM
BLAZIN07SS's Avatar
I'm too JDM for you
a lot of things play into it. such low compression is going to make the turbo even laggier. it's gonna suck hardcore under the curve. now you have this peaky 440whp with no torque. never understood that build
Old Jan 22, 2013 | 07:35 AM
think my car's video is still up on the site first stock motor car over 400whp lol.
Old Jan 22, 2013 | 08:17 AM
link or it never happened.
