NEED MAJOR HELP car = not working
Is there a chance of a massive build-up on the valves from the flooding of the car? If the plugs looked like the had massive carbon build-up to the point they wouldnt even arc "they would not spark at all" then could the same thing happen to the valves? possibly causing a problem?
I disagree. Without it, once he gets this sorted out he will be lean under boost. The SMT-6 and 5th injector are what add fuel under boost.
NOTE: that severe rich condition you had with the faulty injector probably killed the O2 sensor. They're sensitive to rich conditions. It might have killed the cat, too. I've heard of them going bad from too much fuel. But the O2 sensor is a definite. I'm surprised it isn't throwing an O2 sensor CEL.
I'm suprised his O2 sensor didn't throw a code either. They usually get corroded fast when you flood the engine.
First of all the engine would be running in open loop after start up.... there for the o2 sensor would not be at fault. Its something in open loop operation affecting the idle. I dont know what, possibly IAT sensor or even map? Can you get data or a snapshot from the car as it idles bad? Possibly still excess fuel in the intake system or a leaking primary injector?
uploading vids now
http://vids.myspace.com/index.cfm?fu...a-360bca3316fd
here are some vids, the 4th one is when the car goes back to idle normally
If your O2 sensor is corroded, it can't read the amount of fuel in the exhaust/fuel mixture (I think with narrowbands they read by heat...I can't remember right now 100%), so it would think it's running lean when it's trying to reference between your MAF sensor and your first O2 sensor.
But like he said, during warm up, you're in open loop.
It's not loading at work.
Did you do what I suggested?
Can you describe what is happening in the videos?
uploading vids now
#36
Like I've been saying, I think there is something wrong with the 5th injector setup...something is faulty.
Do you remember the time that the car stays in open loop for? Like the temperature?
Also, slowbalt, did you check your MAF sensor at all? How far is the 5th injector from the MAF? Just curious.
#38
The 2.2 does (and all the Delta cars) have a MAF sensor.
#40
I'm trying to find out how close the MAF is to the 5th injector setup to see if possibly fuel was reaching the sensor.
#41
i feel a little dumb right now.....the MAF sensor is the one that goes on the cold air intake on a n/a right?....Im having a long, bad day. if that is the case then the MAF sits just past my cone filter not far from its stock location . How much is a decent 02 sensor i will just buy two, i will ***** off my plasma for the money since i cant drive to work.
#42
Is your MAF sensor in your charge pipe or is it in the pipe/filter setup that goes to your turbochargers compressor air inlet?
#43
What I was thinking.....those two or three heated wires operate at about 1200 degrees F. I beleive the IAT is in the MAF also. At start up the PCM can see the O2 sensor but will choose not to acknowledge it's input. To help heat up the cat the system will adjust the AF Ration to about 14.4 or 14.5/1. Surprised there are no DTC but I assume the PCM has a different MAP for the turbo. Who knows what parameters or values are set for the input/outputs.
#44
#45
I just want to make sure that fuel didn't back up into the MAF sensor.
#46
what is the sensor that sits on the intake manifold right above the throttle body?
#47
The more I read...the more it sounds like possibly your MAF...
http://www.spydermagazine.com/2002/M.../maf_clean.htm
http://www.crcindustries.com/files/19965_1.PDF
Is it connected to the Throttle Body?
Picture?
Picture?
#49
Picture?
Picture?
Have you tried running a heavy jumper directly from the battery to the power input to the piggy-back?
#50
if the piggy back has its own map sensor then could that affect start up? If the piggy back is freaking out and retarding timeing a possiblity?
