Ottp stage 2
Ottp stage 2
Just bought it, says they recommend a h/e with it, anything else I need? Also I've check on there h/e but you can't buy it or anything just shows details, have they not released there's yet?
Their heat exchangers are on backorder, thats why they don't list it. The canned tune is pig rich. Pegged 10.0 AFR when i hooked up my wideband. After i put in meth, dual pass, option b and heat exchanger with a custom tune the thing hauls
Ok this is everything I ordered. Ottp stage 2(2.8 60# injectors gm stg 2 belt and the pcm for that), ZZP S3 h/e, sportlines, throttle body spacer(with meth tap), aem wideband, aem meth kit, hurst short throw. And I believe that was all of it.
Yeah not many people around here do tunes either, would I be ok not running meath for a while though I know its just really to help out. Plus I'm guessing all I have to do down thee road is the meth, option B, and dual pass? Cause iim sure that will keep it even colder. I was also looking into the the coolant resavoir the steel one, I was putting thoughts towards that also down the road
a new tune. not trying to bash, just sharring my own experiences with the product.... i had ottp stg 2, the tune was terrible. i was running a 10:1 AFR at wide open, rich enough to spit raw full out of the tail pipe. they also disable all your VE tables so you relied on MAF for your AFR reference. fine for a race car,but not a car you wanna drive. my car idled terrible, drove terrible and continusously fouled spark plugs on that tune.
and just an FYI, after ottp stg2 i had my car tuned by a proffesional shop and have all cooling mods except meth plus a 3 inch exhaust and tryed every pulley size between 2.6 and 2.9 and made the most power by a fair bit on the 2.9 with 91 pump fuel of coarse...
Sweet, yea for right now I probably will have to just go with the stock can tune until I can get a good tune option b and my dual pass then be able to run my meth lol
Oh and also what good would that steel coolant resivor tank do me?
Maybe hold more and look better in your engine bay, but thats about it.
Also does anyone have any idea how long it takes for them to ship this stuff, I ordered it all on the 28th and I go to ottp and aem to look see and it says processed that's it, I'm already getting my stg 3 h/e tomorrow from zzp
