Forced Induction Turbos/Superchargers
Ported Blower...
Old Jul 18, 2008 | 05:16 AM
SlowBalt_06's Avatar
Ported Blower...
JUST FINISHED UP PORTING THIS BLOWER...BECK GOT ALOT OF IT DONE AND DID A GOOD JOB I JUST CLEANED IT UP AND SMOOTHED EVERYTHING OUT...AND NOW I'M SANDING THE OUTSIDE TRYIN TO GET THIS POLISHED....
Super_SS's Avatar
and what time is it over there?
Old Jul 18, 2008 | 05:18 AM
2 i work get off work at 12am
Old Jul 18, 2008 | 05:19 AM
Super_SS's Avatar
port my turbo?
looks good btw..
thanks and no lol
Old Jul 18, 2008 | 05:24 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Plug those holes with Quicksteel. Buy ACTUAL "Quicksteel".
Old Jul 18, 2008 | 05:36 AM
hungryhip-ccp's Avatar
x2
Old Jul 18, 2008 | 05:43 AM
VeNoM0713's Avatar
how hard is it to actually take the supercharger off? what tools do you need to do it and how long does it take? i would love to plug the silencer holes..
Old Jul 18, 2008 | 05:45 AM
well it takes me 5min probly take you 20-30 i've had mine off about 7-10 times
its simple look for a how to, use the search button... if you still cant find nothing let me know...
Old Jul 18, 2008 | 02:56 PM
yea its easy...idk if i will plug the holes...thinkin bout it
Old Jul 18, 2008 | 03:15 PM
falke401's Avatar
I would be worried about the quicksteel coming off and falling into the engine. It might work fine for a while, but I just don't know how well it would hold up with hundreds of heat cycles.
Old Jul 18, 2008 | 03:22 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Im just curious as to why you didnt use the "quick aluminium" and not the "quick steel"
Old Jul 18, 2008 | 03:26 PM
Brian MP5T's Avatar
BLOW BY: Are you peeps worried about actually loosing performance just so you can put the words "Ported Supercharger" in your signature.
When made, the Eaton housing and it's twin screws are calibrated to run as close to the housing walls as possible to ensure mimimum blow back due to compression. Basically, if you polish any area around the twin screws, you increase the gap and increase the loss of compression.
For the love of god, don't touch the inside of the housing..
Old Jul 18, 2008 | 03:28 PM
BOOSSTED 06's Avatar
this is common sense, and it doesnt look like he touched the inside of the housing. Not sure why you are freaking out
Old Jul 18, 2008 | 03:40 PM
no i didnt touch inside just smoothed what is in the pics
Old Jul 18, 2008 | 04:22 PM
As long as you polish the holes... it ain't falling out.
I've got 5 friends with Grand Prix GTP's that have been running plugged holes with 2.55" pulleys for OVER 20,000 miles. Mine has been in for 5,000.
NOT TO MENTION the fact that if they did happen to fall out... they won't make it past the intercooler.
Haha, funny.
lewisb13's Avatar
Any answer to my question? And the question is serious. If you look up this product there is quick steel and quick alu...
Old Jul 18, 2008 | 04:28 PM
SSCobalt~SSZ24's Avatar
im scared to plug my silencer holes
Old Jul 18, 2008 | 04:33 PM
Quicksteel is Hard Core and can be used to plug a hole in you Block - Rated to 500*F...
QuickAluminum isn't so strong. Its more for quick repairs to hold you over until you get to a shop.
QuickAluminum Review:
When you’re miles from nowhere, this stuff is a blessing for emergency repairs on all aluminum parts, such as broken clutch levers, mounts, etc. Whatever your misfortune, this kneadable, quick-curing-to-rock-hard putty will get you back on the road home or to the nearest repair shop
There's nothing to be scared of.
Last edited by USMCFieldMP; Jul 18, 2008 at 04:33 PM. Reason: Automerged Doublepost
Old Jul 18, 2008 | 04:34 PM
i still worry it will have a negative effect on performance
but lets not turn this thread into that argument
Old Jul 18, 2008 | 04:37 PM
It actually will increase flow, efficiency, and performance. You won't be losing the air that is shooting back into the supercharger through the Silencer Holes.
lewisb13's Avatar
How noticeable is the sound difference? I should grab one of the dB meters from work and test it.
Old Jul 18, 2008 | 04:39 PM
Noticeable. One member couldn't hear his S/C because of his exhaust. He did the hole plug and not he can hear his S/C again.
As far as outside of the car goes... it starts to whine at a lower rpm and its much more intense.
Old Jul 18, 2008 | 07:21 PM
exactly...
Old Jul 19, 2008 | 12:44 AM
brownbandit9's Avatar
does the polishing and sanding of the letters on the inside like you did do anything...i had my supercharger ported but the letters were left there and it was not smoothed out...does that matter really
