Forced Induction Turbos/Superchargers
Rear Trunk Mounted All-In-One Water Alcohol / Methanol Injection Systems For CobaltSS
Old Nov 23, 2007 | 09:33 PM
PhalThrax's Avatar
Just sent an e-mail to your info e-mail address. Looking forward to a response. This looks very interesting.
Welcome to the boards!
Old Nov 24, 2007 | 12:56 PM
stryder's Avatar
hmm intresting i will be in contact.
Old Nov 24, 2007 | 01:57 PM
widebody_balt_ss's Avatar
guys, I have sent an e-mail and left a voicemail with them and cant get ahold of them, as soon as I do I will up-date this thred.
Old Nov 24, 2007 | 01:59 PM
SJSchafer's Avatar
Yea, they probably took the weekend off.
Old Nov 24, 2007 | 02:08 PM
3fo893013L's Avatar
why is the fitting pre drilled into the supercharger? why not in the intake instead?
Old Nov 24, 2007 | 02:19 PM
where do you see that?
Old Nov 24, 2007 | 02:21 PM
spike's Avatar
it may have 2 be mounted after the throttlebody
Old Nov 24, 2007 | 02:34 PM
ill look into this, I dont think thats true though.
if you look in the slideshow at the begining there is one where it is tapped into the s.c and one where there are dual nozils in the intake. so i think its prefrance. i would def go pre blower.
Last edited by widebody_balt_ss; Nov 24, 2007 at 02:34 PM. Reason: Automerged Doublepost
SJSchafer's Avatar
Nope. I already asked. You can go into a TB spacer or into your intake. I would personally go into a TB spacer, but that's just me.
Old Nov 24, 2007 | 07:14 PM
euthanasia's Avatar
The reason why we tapped the blower was because we had been waiting on CA to ship the spacer out and just got tired of waiting. + I had extra cores just incase. BTW we never did get the Spacer
Old Nov 24, 2007 | 07:33 PM
  #36
flathead0's Avatar
just want to be able to come back
Old Nov 25, 2007 | 01:38 AM
  #37
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Originally Posted by widebody_balt_ss
Ill be in contact with you tomorow!
Do you have pictures of the controler?
What defines and separates a water methanol injection system from another is its controller and the quality of components used through out the system. These are by far the most advanced and versatile controllers on the market with more features built into them then any other competitors controller on the market.
With one controller you can run it on anything from a naturally aspirated vehicle to a turbocharged/supercharged gasoline or diesel application regardless if it's carbureted or EFI. One controller does it all!
Compare for yourself and see the difference.
  • 100% digital processor for lighting fast response
  • Quick, easy to use adjustment knobs
  • The only controller which allows you the ability to manually adjust and change the start pressure, max pressure and curve of the system.
  • Heavy-duty metal housing protecting the controllers CPU. Not plastic like other competitors controller.
  • Greater range of adjustment then any other controller on the market with the ability to run true 2d Map using MAP, MAF, TPS, EGT or AIT in addition to Boost.
  • Built in boost port for carbureted or EFI users who want to run a mechanical boost signal
  • Built in serial port for connecting laptop for enhanced tuning features such as running multiple inputs (2d mapping) at once, data logging, saving and locking your settings.
  • The only controller which allows you to use any of the following signals; Mechanical boost signal, EGT, TPS, MAP, Mass Air Meter, AIT, ACT or any other 0-5 volt sensor on your engine to base mapping of off.
  • The only controller with a built in data logger allowing you to record and review the input signals being ran into the controller. Perfect for those who want to review the systems performance during a racing event, towing, normal daily driving, Etc.
  • Built in status monitor which not only indicates when the system is activated but also performs a system function check everytime you turn your car on indicating the systems CPU is operating properly.
  • The only controller which comes with free Windows based software
  • Unlike the competitors "kits" our "systems" come pre-wired, tested & ready to go ensuring you will not only receive a fully functional system but also saving you the troubles of wiring the system yourself and potentially making a mistake and damaging the controller.
Here are a few pictures of our controller below. We used an actual brush aluminum panel overlay with the ink protected under a thin layer of glass to prevent it from being worn off. This is the same quality panel overlay used in aircraft. It’s extremely durable and very attractive at the same time.
Let us know what you guys think.
Originally Posted by spike
welcome........kit looks 2 very nice..........how tuff is the wiring...............is it plug and play or basic wiring? may be dumb Ques. but ............ didnt see it asked
Unlike the competitors "kits" our trunk mount "systems" come pre-wired, tested & ready to go ensuring you will not only receive a fully functional system but also saving you the troubles of wiring the system yourself and potentially making a mistake and damaging the controller.
As for the wiring it's as simple as it gets. There is one ground wire which you will ground to the floor of the vehicle using our grounding strap and self drilling grounding screw included with the system.
Next, you will hook up the positive wire to a 12 volt ignition on power source. We include 10 ft of wire with each kit.
Thats it! We pre-wire and test the system before it's packaged saving you the trouble of wiring everything yourself and possibly making a mistake and damaging the controller. Installation can be completed in under 60 minutes once familiar with the system.
Let us know if you have any other questions or how we can help.
Originally Posted by SJSchafer
Yea, I have been investigating a bunch myself. I have looked at the devils own, coolingmist, snow performance, AEM and an assortment of others that no one has heard of. For the stage 2 progressive kit, this and coolingmist are the most expesive, but the difference is versatility and functionality is huge. Like I said. This one and the cooling mist are pretty much the same, except that this one comes with something that the coolingmist doesn't (checkvalve or better jet or something), and this one is preassembled and tested.
There was actually one of these that "assumes" we have our own tank or are using the washer fluid tank. I wonder what the instal on that one would be like.
Our progressive controllers are more expensive as they do come packed with many more features and are built using only the best quality components.
Check out our post listing all the benefits and compare for yourself to see the difference.
Received your message. We will call you on Monday morning or if you are available I'm sure one of us can call you tomorrow if your available during the day.
Old Nov 28, 2007 | 12:13 PM
  #38
AIS's Avatar
AIS
All new fabricated black anodized aluminum tank brackets coming in the next week. We will post pictures as soon as there in stock. This will replace the rubber straps currently being included with our kits.
Old Nov 28, 2007 | 09:42 PM
  #39
Avrj123's Avatar
Sounds great, thats my next upgrade once i get the car on the road again.
Old Nov 28, 2007 | 09:49 PM
  #40
SJSchafer's Avatar
I'm hoping my GF already ordered me one for my b-day. Question: Are the steel braided an upgrade? How much? I didn't see the info on your site.
Old Nov 29, 2007 | 10:52 AM
  #41
AIS's Avatar
AIS
Yes the steel braid hose is an added upgrade. We haven't listed it on our site yet as we just started making the lines. We should have the site complete sometime next month.
The cost for the upgrade is $99.99
Old Nov 29, 2007 | 11:05 AM
  #42
PuSha050's Avatar
definately a sweet setup
Old Nov 29, 2007 | 11:14 AM
  #43
AIS's Avatar
AIS
Sounds great. Let us know if you have any questions.
Wait till you see our new fabricated black anodized tank brackets.
Old Nov 29, 2007 | 10:13 PM
  #44
SJSchafer's Avatar
Damn it. That means my GF almost definately didn't order the stainless. I don;'t even know if she ordered the kit yet, but she asked me about my engine, so I assume she did...
Oh well...
Old Nov 30, 2007 | 12:19 PM
  #45
AIS's Avatar
AIS
Oh well...
Not sure if she did order a kit. If so, it will be a surprise or not.
Old Nov 30, 2007 | 12:36 PM
  #46
thwick's Avatar
this might just be my next mod when i get some cash.
Old Nov 30, 2007 | 03:45 PM
  #47
SJSchafer's Avatar
Oh, you know. How many orders did you get from San Jose, CA in the last week or so? You just aren't saying.
Old Nov 30, 2007 | 11:11 PM
  #48
You guys Know It! Stage 2 AIS kit, polished 2.7 pully, and 60 lb. injectors. now im just waiting on my port and polished supercharger. It should be about a week. or two!
I am sooo happy right now just looking at this cant wait to get it tuned.
Old Dec 1, 2007 | 04:13 PM
  #49
AIS's Avatar
AIS
Are you getting a polished and ported blower from Junior? I've scene his polished supercharges. What a difference it makes under your hood. Post pictures once you have everything installed.
Old Dec 1, 2007 | 06:35 PM
  #50
yep, you know it.. junior is hooking me up. i will have tons of pictures. we got tons of ice and crap tho. it will be a while
