S20G Help
S20G Help
I am looking at the S20G turbo on Turbo Tech. I am just wondering how much better this turbo is than the one that comes stock with the LNF. I know that it is better but i dont want to waste money. Does anyone know if this is a bolt in kit or is there more to it than that.
You would need the manifold, turbo and V-band downpipe to install... (making a note on the downpipe as it has a 2 bolt flange and you need a 3 bolt flange for the SS/TC exhaust...)
Stock turbo is good around 350 HP, this one should put you over 400 HP
[QUOTE=TurboTechRacing;4050981]You would need the manifold, turbo and V-band downpipe to install... (making a note on the downpipe as it has a 2 bolt flange and you need a 3 bolt flange for the SS/TC exhaust...)
Stock turbo is good around 350 HP, this one should put you over 400 HP[/QUO
what would the total price be for all that and do you carry all the stuff that i would need
Everything is on www.TurboTechRacing.com...
We would suggest however to wait to fall time, when Hahn will be coming out with a actual bolt on turn upgrade system specifically for the SS/TC which will put out more power...
