S256ET on 20psi in a 2.1L Expected Numbers?
So I'm going to run my wastegate directly to my boost source on my car for about 1500 miles just to keep things safe during break in. My wastegate spring is a 20psi spring. My question is, what are the numbers I should be expecting? I was looking on the SRTForums and saw the SRT4s making around 380-400whp on pump gas. I was thinking I should be seeing similar numbers or maybe slightly higher as most of these guys were on the stock head and cams at the least and I'll be running cams and a ported head on my built engine.
Why do you care about break in power? You shouldn't be abusing the car during the break in. And once you're ready to push the car, you are gonna up the boost and hopefully get it tuned before beating on it. So in theory, you should never make whatever power it would make at that level.
But yeah, under 400 assuming no tune and 20 psi.
so you think i should of went with a 252et instead of the 256et for my swap? off thread topic but something i'd like to know. I know someone who is running 26psi on his 256et with stock motor
PMed back, but no the 256 is a great turbo, just turn it up a bit. For instance my car with the 5857 made just 320 whp on 15 psi
exactly people don't seem to understand that driving around dd'ing for 450+ whp isn't a good idea lol my car is setup now for 10 psi for dding and 15 psi for some fun
I can't turn it down any lower with a mbc due to my 20psi wg spring. Now if I put the 7psi spring back in, I can crank it up to 15psi. Some people don't realize your lowest boost setting is whatever your wastegate spring is rated for.
It was easier for james to tune for higher boost pressures with the factory wastegate solenoid and its easier on the solenoid. Remember, I had the turbo on the stock engine.
And I wasn't accusing you of not knowing that. I was just saying some people...no need to get mad...if I was saying that I would have said "apparently you don't know what a wastegate spring rating really means"
a spring that stiff though just isn't necessary unless you'll be either running sping only, 24/7. or running boost higher than any cobalt has seen. i'm on a 9lb spring and am still able to run 30psi efficiently. if we turn it up on this freshening of the engine we'll put a different spring in but thats just an example.
Just for reference. Paintballerr78's car on the 5557 on 20psi and E47 on 22* up top made 377whp on a dyno dynamics. That was on his winter timing table which was coservative for E47, but still more than 91 octane will take. Just some food for thought I guess lol
mine on 91@20psi made 443..
