SMG's first...REMOTE MOUNT TURBO TWINCHARGED LSJ!!!
#176
I think you can only bypass @ 4k and above through the computer. If you can do it below that I want to know where for my twincharge tune. I have searched and cant find. 1st and 2nd boost limits in torque management and it only limits above 4k. Also a couple other tables for the rest of the gears are from the same RPM range.
IIRC ZZP said you only lose a small amount of power when the blower is in bypass. So clutch should not be needed, maybe to recoop <10hp.
#178
call smg up! va beach isnt that far correct? and your in the service? maybe if you go on deployment again he could take your car and do it while your gone and have it sitting pretty waiting when you get home! no down time for you and he has time to experiment with the tune or whatnot to get the post out of it for you when you get back stateside!
#179
Only thing is I just got back from a deployment in April. Had this been out last year, I'd have been golden. But still, there are ways around this. And I will be talking to them eventually.
#182
They're the only place that touches my car for anything. Been working on my car for 3 years now. prices are great, you can call him with questions whenever and he'll answer them, quality is top notch, has all the stuff to do a full build in house and dynotune without leaving to go out of house anywhere. Cant beat it.
#183
I have the same concept pretty much. I only have one person that tunes my car now. I am pretty interested to see what the tvs will max out at, and then I'll probably branch out and get some more done. But I am intrigued.
#184
I think it would come down to where the turbo would need to come on. The tvs produces around 20 psi around 4500 rpm on a 2.95 sized pulley. My thinking is that is proper airflow could be on hand from around 4k rpm, the turbo would take off, and the powerband for the turbo would take account for 3k rpm at least. Even if the boost was controlled by rpm in different gears, it would still be a ridiculously strong build that no one would expect.
Someone correct me if my thinking is off.
The SMG and ZZP setup both use the stock 3.35" pulley on the M62. If they disengage the SC at 3000 or 4000 engine rpms the M62 is only spinning at 5600-7000 rpms.
If you wanted to get all of the low end boost available then install a 2.5" pulley on the M62. At 3000 engine RPMS the blower would be spinning at 7800rpms and at 4000 engine rpms the M62 would be spinning at 10,000 rpms. Still well within the efficiency range of the M62.
There are too many variables to begin talking about a compounded system.
Over 400whp has been done on fordged internals not including sleeves. You should have a leg up on that.
#192
Does anyone know if Fred is offering this kit for the public yet? Im very interested, but i havent seen any dyno numbers or ballpark pricing. Ive been checking out the zzp setup, but realistically im not going to travel half way across the country for install.
Fred: Help me wake the beast!
_____________________
06 SS/SC Laser Blue Metallic, G85, gm S2, 2.9, DP+B, CXR HE, CAI 13,000 on the odo
#195
just got an email from Fred Jr. Says the kit is almost ready for launch. Id love to have this in my car before the nice weather hits.
__________________________
06 SS/SC, Laser Blue Metallic
#197
I have had this idea for a few years... Damn you for being able to do it before me!!! J/K Glad it is working out for you, now I dont have to worry about my theory since you have proved it. Now I just gotta find a way to route the piping to the front since my auto trans doesnt have that fancy cutout... Also I will be using a CT26/M62 combo on a fully built 2.2 at stock compression(10:1)... Any tips? Also if you get a piping kit put together(minus turbo/WG/BOV/ect) I will probably be ordering it from you.
#198
you should make this fit the auto 2.4 cars and route the pipe up the other side so we can have a rear mount turbo kit as well. make more cash for your shop since the smae kit could fit many vehicles with a small re route kit
