Forced Induction Turbos/Superchargers
Some Supercharger ?'s
Old Aug 16, 2006 | 04:14 PM
YellowLT's Avatar
I am working on developing a supercharger setup for my 2.2 but i have some questions. But let me start with this, I know there is no tuning(yet) I know what i can safetly run, boost wise on Stock internals, and No i am not just buying a SS S/c
so now that that is out of the way.
1. What style is the pulley shaft on the SS Eaton, Ie. Splined...
2. Is it better to put the I/c between the S/c output and the T.B. or between the intake and S/c?
3. Where is the Maf on the SS S/c? ( I belive in the wheel well) and does the 2.2 and 2.0 use same Maf
4. How does the Eaton get it's oil
Those are the big ones for now.
Old Aug 16, 2006 | 08:31 PM
YellowLT's Avatar
Anybody????????
Old Aug 16, 2006 | 08:34 PM
BOOSSTED 06's Avatar
3 The maf is down under the headlight, right above our filter, i am not sure its the same maf, im almost positive it isnt.
the supercharger has its own self contained oil
StinkBOMB's Avatar
1. Press on
2. If you want an IC on a roots blower, the only place it will physically work is underneath the blower.
3. No clue.
4. It's a self contained unit.
Old Aug 16, 2006 | 08:35 PM
ideally you would want the ic or actually the aftercooler, after the s/c because the s/c actually heats up the air mechanically
Old Aug 17, 2006 | 12:05 AM
YellowLT's Avatar
Let me elaborate on the Intercooler, im looking at using a centrifigual S/c Vortech or Procharger, Leaning towards Procharger, so would that still mean after the S/c
Old Aug 17, 2006 | 12:20 AM
Cobalt_Supercharged's Avatar
Centrifigual creates less heat, and don't require an IC for lower boost, but mid-high boost you can run an IC post s/c. You always want to run the IC after the S/C or turbo because they create heat as a result of the compression.
Old Aug 17, 2006 | 09:13 AM
YellowLT's Avatar
Thanks Guys, Can you elaborate on the press on pulley what keeps the pulley from slipping on the shaft.
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
medic710
Sep 6, 2015 08:53 PM
