Forced Induction Turbos/Superchargers
SpringerDesigner's Supercharger Build
Old Aug 10, 2010 | 12:42 PM
Zdeuce4's Avatar
Keep the 60s man vince got mine down finally
Old Aug 10, 2010 | 04:03 PM
springerdesigner's Avatar
I am keeping them. Trying to sell the 42's now though.
Old Aug 11, 2010 | 12:30 AM
After I throughly cleaned and sanded the blower, I laid down the red base coat:
After it dried, I masked off the areas I wanted to remain red:
Then I laid down the black coat and then the clear coat:
Old Aug 11, 2010 | 12:34 AM
Maupin SS/SC's Avatar
good work. hit me up if you need local help
Old Aug 11, 2010 | 01:01 AM
thanks man. I'll be at elite's parent's place on the 17th and 18th doing the build.
Old Aug 11, 2010 | 01:28 AM
elite_Cyborg's Avatar
it will be next to my whip
Old Aug 11, 2010 | 01:35 AM
i wanna go :P
Old Aug 11, 2010 | 02:17 AM
come and help with the install so I can paint more things and do more visual mods
got to get it running by 2-3 PM on the 18th so I can get to the dyno.
Old Aug 15, 2010 | 01:47 PM
VERTZX's Avatar
looks good, god i want my supercharger painted =/ just dont want to have to worry about 1 taking it off, and 2 heat soak. looking good bud!
Old Aug 15, 2010 | 10:05 PM
thanks man. I was pretty worried about heat soak as well but I'm show before go
Old Aug 18, 2010 | 02:52 AM
  #36
Well it's all in minus the oil catch can and the rerouting of the washer fluid line (sensor swapped just need longer washer fluid line to run from driver's side to the passernger's side.
Got a couple of issues to work out, i.e. car starts but instantly dies. Scan tool is showing that it's the TB.
DIC also reads "Engine Power Reduced"
Hopefully we figure it out soon.
Last edited by springerdesigner; Aug 18, 2010 at 10:08 AM. Reason: Automerged Doublepost
Old Aug 18, 2010 | 10:08 AM
  #37
Some shitty pics:
Old Aug 18, 2010 | 10:52 AM
  #38
Zdeuce4's Avatar
u did all that painting and didnt do the valve cover?
Old Aug 18, 2010 | 10:54 AM
  #39
I know... I know.
The K&N intake I painted didn't fit so I now how the polished OTTP 3"
Old Aug 18, 2010 | 11:04 AM
  #40
Looks good man love it
Old Aug 18, 2010 | 12:59 PM
  #41
[ECM] P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance (SES) (Pending) (History) (Current) (Immature)
[ECM] P2101 - Throttle Actuator Control Motor Circuit Range/Performance (SES) (Pending) (History) (Current) (Immature)
[ECM] P2176 - Throttle Actuator Control System - Idle Position Not Learned (SES) (Pending) (Old) (History) (Current) (Immature)
Old Aug 18, 2010 | 02:42 PM
  #42
Illini_06SS's Avatar
Couple things.
1. If you pull up the plastic cowl cover, you can pull off the stock washer line and flip it over (run it the opposite direction) and it'll fit perfectly down to your washer bottle!
2. Looks like it's a wiring issue with the TB. I would start there.
Old Aug 18, 2010 | 03:36 PM
  #43
Originally Posted by Illini_06SS
Couple things.
Come to find out we had the IC pump hardwired into a unused fuse tap and it was causing the tb issues. After putting it on a relay it was fine.
Old Aug 18, 2010 | 11:42 PM
  #44
WOW. Just got back from a night of data logging and just plain having fun..!
This car is awesome. Pushing 10 PSI currently. Have a couple of issues though:
1. When in reverse and any "lunge" will cause my pulley to grind the frame.
2. On my way home tonight, my car "died" kind of. All the power went off but the car was still running. Lights, gauges, radio, everything inside, etc. all shut off and then had to reset themselves, usually taking anywhere from 2-5 seconds. Although the car never shut off itself, it's pretty scary when driving down the freeway at night and your lights shut off..! This happened 5 times on the way home. 4 out of 5 were during WOT runs. 1 out of 5 was shortly after a WOT run where the power kicked out. Now because of these mishaps, I have a CEL again. I believe a datalog that Riley will be sending captures this occurrence happening. Altogether, tonight between Riley and myself, we did approximately 15-20 WOT pulls and this happened 6 times.
Oh I almost forgot:
WPP is my BFF.
Last edited by springerdesigner; Aug 18, 2010 at 11:42 PM. Reason: Automerged Doublepost
Old Aug 19, 2010 | 12:33 AM
  #45
N1ckateen's Avatar
mmm.. i see black valve cover and red voil packs in the future, possibly wire looms? looks great man. grats on the succesfull build.
Old Aug 19, 2010 | 12:35 AM
  #46
yeah lots of engine appearance mods to do.
36 hours total in this build.
Old Aug 19, 2010 | 08:38 AM
  #47
Oh I almost forgot:
WPP is my BFF.
1. It would do that on my car, too. With time it'll wear a groove and it won't happen anymore... Or you can get stiffer engine and tranny mounts to negate the problem. Stupid automatics...
2. No clue on this one. I'm guessing it has something to do with where you spliced into.
Old Aug 22, 2010 | 09:56 PM
  #48
Possibly better pics tomorrow.
Old Aug 23, 2010 | 09:52 AM
  #49
Old Sep 2, 2010 | 11:09 PM
  #50
It as raining out but still decided to have some fun. Sorry for the slippage:
http://www.youtube.com/watch?v=VtLHBUmqB3o
Boost Gauge. Looks like 11-12 PSI.
http://www.youtube.com/watch?v=QelYJuDXfRw
