Forced Induction Turbos/Superchargers
Stock 2.4L internals
Old Aug 30, 2007 | 03:02 PM
BrickCityCobalt's Avatar
I have $5000 saved up for a turbocharger and im looking to get the hahn. With the hahn being 4k id like to add $1000 in extras. Should i spend this extra 1k on internals for the engine or am i safe with around 300hp?
What are some safe HP/boost amounts for the 2.4L internals.
Thanks!
Old Aug 30, 2007 | 03:05 PM
joeworkstoohard's Avatar
Thanks!
it's been my experience if you're going to go with large boost... it never hurts to upgrade internal parts.
Old Aug 30, 2007 | 03:11 PM
NJHK's Avatar
You're going to spend more than 1k
1k will get you pistons and connecting rods and that's about it.
You also have to get head studs or bolts, head gasket and atleast get the engine balanced.
Old Aug 30, 2007 | 04:24 PM
Are there any sites you recommend for pistons and rods?
Old Aug 30, 2007 | 04:49 PM
zinner's Avatar
Moderator Alumni
You have an exhaust? Maybe some gauges?
Old Aug 30, 2007 | 05:09 PM
REDFOCZ's Avatar
Dont forget about a clutch and flywheel.
Old Aug 30, 2007 | 05:38 PM
I have the GMPP exhaust. will that be alright with a turbo?
Old Aug 30, 2007 | 05:50 PM
REDFOCZ's Avatar
It's only 2.25 kinda small imo for a turbocharged engine. I would go with a 2.5 inch
Old Aug 30, 2007 | 06:26 PM
IonNinja's Avatar
spend the extra 1K to monitor your motor, A/F gauge, boost gauge and EGT gauge
I wouldn't push the 2.4 motor anywhere near 300whp if you'd like a reliable setup
Old Sep 2, 2007 | 09:21 AM
celicacobalt's Avatar
300 whp has been reliable on the solstices so i would say youll be fine with the right tuning. and the extras like gauges and a bigger exhaust. upgraded brakes
Old Sep 2, 2007 | 09:27 AM
njg5gt's Avatar
i would go with the rebel turbo kit. it's cheaper so you can spend more on making your engine stronger
Old Sep 2, 2007 | 10:34 AM
yoppzilla's Avatar
I was under the impression that the hahns turbo holds up just fine with stock parts from what they advertice, so probaly any internals that you could do would help, but from what i got with their turbo its set up to work fine on a stock 2.4 auto
Old Sep 2, 2007 | 12:13 PM
NJHK's Avatar
To the original poster
Seriously do some reading up on how Turbocharged systems work. Even though you're buying a kit, knowing what everything does could make or break your project. Also read up on Fuel Injection systems and the basics of Engine Management Systems.
Old Sep 2, 2007 | 08:38 PM
x2.
also, i'd seriously consider reading up on the basics of modifying the EFI system and tuning it.
it seems, to me, that every car is different, and a "Canned" tune job may not be the best.
Old Sep 4, 2007 | 11:56 AM
kovich14's Avatar
At the 300 HP mark (at the crank) you shouldn't HAVE to have internal work done. I have great faith in Hahn's assessment of the the LE5's ability to handle the power; few people have worked and tested the 2.4's strength as extensively as him. I personally would use the remainder of your money for gauges (Boost, A/F) to monitor your system's safety and performance
Old Sep 4, 2007 | 11:44 PM
06_cobaltSS's Avatar
Hanh has pushed the internals to over 400+ hp, and running at 29 hp at the crank at 8psi and 241 at the wheels.
Old Sep 13, 2007 | 02:42 AM
CobaltFan06's Avatar
Hahn is great, but a bit overpriced... guess they can be thou
Old Sep 13, 2007 | 08:56 AM
g5mike's Avatar
clutch you will need,indeed!!!
Old Sep 13, 2007 | 09:14 AM
monkeiboy's Avatar
Yeah the engine I think is fine up to 400 hp. That seems to be the general consensus anyway. But the transmission WILL NOT hold up. Plus you have none of the supporting modifications. Oil Cooler, TRansmission cooler, strut braces, at least a 2.5 inch exhaust, all that jazz. The engine is fine, the rest of the car isn't.
Hahn's turbo kit is set up to boost fairly conservative numbers, He was pushing about 250HP and into the 13's on stock tires.
Old Sep 13, 2007 | 11:35 AM
im running 234 whp and 244 wtq and im at 14.1 but that was in hot weather, im pretty sure if i go again now i'll be in the 13's but i have wider than stock tires.
Old Sep 13, 2007 | 12:23 PM
Jackalope's Avatar
The 2.4 uses forged rods so they'll be just fine. Our crank is forged too so problem there either! If you plan to go WAY high you may consider new forged pistons and total seal rings too. The rings are free hp!
Old Sep 13, 2007 | 03:36 PM
Brandon97Z's Avatar
Yeah those strut braces are key with any turbo kit
Old Sep 14, 2007 | 02:52 AM
Schultzay's Avatar
what are the limitations on the manual transmission??
Old Sep 14, 2007 | 09:56 AM
kovich14's Avatar
i hope you are being sarcastic about the strut braces.
Old Sep 14, 2007 | 04:24 PM
Sw4y1313's Avatar
No one really knows yet.. I plan on finding out soon
