supercharging my 2.4 soon
Harness you bought works perfect, thats what I did.
LSJ TB To Purge Solenoid Tube- Just buy it, its nicely formed to go around the m62 and connect to the tb.
LSJ Power Brake Booster Vacuum Hose-I dont remember this one, what is it connected to? if thats the 3/4 hose thats on your stock mani, it moves to the barb on the m62, it connects with no issue, its just a C clip.
For the lsj brake booster i dont know even what thats for, its just in all the list of builds on here, i thought id ask to make sure ..
I have the sc kit purchased from a member here.
Other parts i purchased:
New LSJ Radiator Hose from zzp did nt like the other one..
ZZP supercharger oil
LSJ windshield washer reservoir + pump to relocate.
MAF extension from zzp
Painted the Torque Damper Bracket Flat black
6 to 8 pin tb rewiring kit
#41
Ok guys here is what im using:
42lb injectors
stage 2 hub 5 bolt with 2.9 pulley ( need to order that from zzp ) right now i have the 3.1 pulley that came with the kit.
Cobra heat exchanger
Either i use the stock filler neck or im planning to get the option b reservoir and deleting the stock filler
( I dont have a dual end plate )
Will it be ok for now lets say till next summer i use the cobra heat exchanger.
Im planning to get the aeroforce interceptor gauge too
so im quite tight on budget..
let me know what you think will it be ok with the cobra..
thanks
D
42lb injectors
thanks
D
