Turbo FAQ Possible...what should I add?
I was just curious, are there any type of questions and answers that I should add to the Turbo FAQ?
I haven't updated it in a while so I thought I'd ask.
What you guys think?
Yes... please post up turbine efficiency maps and the details behind them. Then focus on how overall system efficiency of a turbo is much less than just reading the compressor efficiency map.
I'm going to have to read up on reading turbine maps myself...this is going to be a work in progress and probably a week or 2 of gathering info.
Ta da.. you have found the best kept secret in the turbo industry.
Garret only shows one efficiency value (usually peak) and therefore not many people outside the industry get access to these maps.
Garret does an excellent job of describing the compressor side...
http://www.turbobygarrett.com/turbob...o_tech103.html
Now here is a single curve turbine map... FAR from complete..
Take note, there are no speed lines nor mention of efficiency outside of that curve.
yea actually....since there are a lot of threads on it...add a little bit specifically for the cobalt on the turbo kits coming out.
theres a lot of questions on "what do i need to upgrade with my turbo to push X HP?" or "what should i add for my automatic transmission to handle a turbo setup?"
Could you also include stuff that goes for high horsepower applications, like we've been talking about. Converting a returnless fuel system to returned. If you want i can help. I will be doing it, because of the reasons you have stated, it is definitely a needed thing. i want a daily driver, and doing it will make it much safer. I can right a review or you can using pictures that i take or something to that effect.
http://www.ecotecforum.com/forums/showthread.php?t=3162
You may want to get a bit more indepth with the intercooler part. This is a VERY important part of any forced induction setup. You should give a general idea of when an intercooler is needed, because it is not needed in all applications, and address the different types of intercoolers and their efficiency/effects on the system. I see people build/buy turbo kits and use some 2,000 dollar turbo so it flows the best/is most efficient so they can get big power, but they use some shitty intercooler that gives a boost drop of like 1.5psi and is terribly inefficient. I am not sure if you did or didnt, but you should also address how important the wastegate is, just so people know. Buy a shitty turbo, buy a shitty intercooler if you want, but do NOT skimp on the wastegate EVER.
yea, it may not really be FAQ stuff, but it's important. People don't research the wastegate enough or get a shitty one, spike and blow their motors even with their kit costing tons of money. and the intercooler thing is just good to know because in certain situations, it may actually be better to go with a smaller intercooler etc. or even in some (this barely ever happens in small displacement engines) with like a 5psi setup you are better off not intercooling at all sometimes. Just some thoughts, not really necessities, but they might be helpful.
"Which wastegate should I get?"
"Tial...that's it!"
lol yea pretty much. Chinese sweat shop turbo = sure if you want. Chinese sweat shop bov= sure if you want. Chinese sweat shop wastegate= sure if you wanna spike to 25psi on a 6 psi spring and blow your engine.
Just make sure that the one your buying really is a Tial. Theres a lot of fakes. Might not want to E-Bay that one.....
I'd like to know more about air to air, and water to air intercoolers. What the differences are and which is better. Right now the setup I'm running I'm using the stock intake manifold and making an adapter plate for it, so I'd use the stock intercooler
