Forced Induction Turbos/Superchargers
For using meth, boost juice or washer fluid better?
Old Jul 9, 2008 | 07:50 PM
celicacobalt's Avatar
Question For using meth, boost juice or washer fluid better?
Was having a discussion with someone about using meth on my car and they said that alot of people use washer fluid but they wouldnt suggest it since they didnt want soap stuff in their engine. So whats the difference between the high priced boost juice stuff and freezing washer fluid? Are there bad additives in washer fluid that shouldnt be going into the engine?
Old Jul 9, 2008 | 08:49 PM
mike25's Avatar
i dunno bout that...i thought methanol formed into a gas or something when it hits air..could be wrong though...washer fluid is just water
Old Jul 9, 2008 | 08:58 PM
BriantheLion26's Avatar
-25 degree PEAK washer fluid is like 30-35% methanol and water. Thats it. Blue dye, duh.
Shake up what fluid you want to run. If it foams up, it has detergent in it and you don't want it.
The more meth, the more octane. More water, more cooling. That should pretty much sum it up.
Old Jul 10, 2008 | 09:05 AM
any known good brands of fluid?
Old Jul 10, 2008 | 10:00 AM
lsjwannabe's Avatar
add a bottle of heat or two and you have a 50/50 mix for much cheaper
Old Jul 10, 2008 | 12:54 PM
is 50/50 the ideal mix?
Old Jul 10, 2008 | 12:58 PM
lsjwannabe's Avatar
yes for power and cooling. you want more power go with more meth
Old Jul 13, 2008 | 11:43 AM
devilsown's Avatar
50/50 mix is the most ideal mixture.
The cheapest way about getting this is buying distilled water at a grocery store. Then fine a methanol supplier in your area and just mix it 1/2 and 1/2. Finding the methanol can some times be tricky in some areas.
We also do sell it already mixed.
http://www.alcohol-injection.com/pre...-brew-125.html
Old Jul 13, 2008 | 12:24 PM
Sharkey's Avatar
methanol isnt always hard to find. if you have a racetrack close by fuel is often sold their, or go there and ask a racer were they get it. dirt bike shops are also another place to try, or any performance shop should know were to get it.
Old Jul 21, 2008 | 01:18 AM
brownbandit9's Avatar
i just bought a gallon of 100% methonal for 4.50 then a gallon of distilled water for 1.00 so i go 2 gallons of 50/50 mix for 5.50.........i dont know but thats not alot of money at all....spend the extra 2 dollars a month for the real stuff
Old Jul 21, 2008 | 10:43 PM
whered u buy 100% meth?
Old Jul 22, 2008 | 01:51 PM
place called dons hot rod shop....theres like 10 stores in tucson that carry it....just look for racing shops in your area...not tuner compact shops but dragsters and muscle car hot rod shops if that makes sense
Old Aug 6, 2008 | 02:24 PM
devilsown's Avatar
If people look around there are lots of places you can find methanol for cheap.
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
