Forced Induction Turbos/Superchargers
VFT (variable flow turbo)???
Old Oct 21, 2009 | 12:07 PM
MadBrad's Avatar
Does anybody know how long these have been around?
Old Oct 21, 2009 | 12:40 PM
Cigar Hero's Avatar
same but different, here's a little something on the subject
FROM: http://www.autoblog.com/2006/03/01/g...che-911-turbo/
Porsche's variable turbine geometry (VTG) setup on the 2007 911 Turbo was developed in close cooperation with Borg Warner Turbo Systems, and is based on technology which has been widely and successfully applied to diesel engines since the early 1990s. It is nearly identical in concept to other turbo manufacturers' variable nozzle/geometry compressors, including a system that was briefly used on a series gasoline production engine in the late 1980s. This application encountered difficulties due to high operating temperatures -- a problem not easily solved with contemporary materials -- and production was stopped after a limited run.
After nearly two decades, aerospace-grade materials have allowed the progression of variable-geometry turbo technology to the point that it can now reliably operate in the higher-temperature environment of turbocharged gasoline engines. Porsche's version of variable turbine geometry in the 2007 911 Turbo incorporates these latest material applications, plus a sophisticated control algorithm. The combination produces the advantages of both small and large turbochargers, generating a much wider plateau of torque and providing quicker response compared to the previous generation 911 Turbo, while providing the reliability of fixed-vane turbochargers.
Old Oct 29, 2009 | 01:23 PM
jrocstar's Avatar
lots of drag snowmobiles run these. they carbon up alot and the vanes stick. you can watch a video on them. they are EXTREMELY efficient and provie instant boost response with high flow capabilities.
also known as variable vane turbo
Old Oct 29, 2009 | 01:31 PM
boosted4dr's Avatar
On disels for sometime....
Old Jan 9, 2010 | 01:03 PM
firerat's Avatar
Who makes these? Can I get one for my Cobalt?
Old Jan 9, 2010 | 02:01 PM
Maven's Avatar
I dont have experience with them on performance vehicle but on the diesels they are computer controlled. The computer basically opens and closes vanes that form the side of the turbine housing, when closed it makes full boost, the more you open the vanes the less exhaust is used to spin the wheel.
Old Jan 9, 2010 | 02:35 PM
buellfooll's Avatar
Ask and ye shall receive.
http://aerocharger.com/
Old Feb 22, 2010 | 07:23 PM
jrocstar's Avatar
search quick spool valves guys use these on rear mount setups and they work really well. have to have a divided flanged exhaust housing though
Supercharged06SS
Dec 11, 2022 04:47 PM
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
maliki778
Oct 1, 2015 07:39 PM
Sep 27, 2015 08:53 PM
