Forced Induction Turbos/Superchargers
why am i
Old Oct 1, 2010 | 09:59 PM
O9cobaltSS's Avatar
why am i
boosting 14psi and not 15?
3rd gear WOT
mods in sig. i prly need a tune right?
Old Oct 2, 2010 | 07:34 AM
joshcsepegi's Avatar
because boost is a measure of the resistance of airflow in your engine. so its the access that your engine can not use. when you do things like open up exhaust, or port a head your more efficiently moving air with your engine and the boost pressure will decrease.
Old Oct 2, 2010 | 08:09 AM
MoePwR's Avatar
and your restricted because you dont have a tune. the car is set up to be at 260/260 the boost just adjusts to that hp/tq. like if your in higher altitude youll have more boost because of the air density. its only from i believe like 11-15 psi....
