Will this garrett turbo work on our cars?
yep that came off a diesel truck of some sort....... maybe an isuzu or something? they always have big hotsides for flow and little compressors for quick spool up due to lack of rpm potential. anyways what do u want to put it on again........... even if u do an equal length twin scroll manifold it still is not going to spool real quick. i thougt it was a divided t3 hotside. judging by the size of the compressor wheel and ur thumb in the pic (and thats what helped me to detemine that it wasnt a 50 trim........ well that and 50 trim t3/t4 turbos sit in .60 a/r housings not .50 a/r)
mike
mike
definitely looks like a t4 exhaust housing. im not sure you want to run a t4 exhaust housing on a 4 cylinder. its going to be laggy. my t3 .82 ar exhaust housing doesnt spool till 4500rpm so i cant imagine the t4 housing. does the exhaust housing have an a/r stamp on it?
mike
whats ur setup consist of and how much power are u making?
mike
E covered turbos are smaller than S. E usually have 2.75 or 3" inlets, while S covers are larger and typically have 4" inlets. A Hybrid E has the smaller size, but a 4" inlet.
dezod a divided housing does not divide the intake and exhaust pulse.
to the OP...... first of all the pairing is based off the firing order and in most 4 cylinder cars cases thats gonna be 1-3-4-2.......... 1 and 4 are paired and 2 and 3 are paired. the whole point in this is so the exhaust pulses hitting the turbine wheel are not disturbed by the next pulse in the firing order. so lets say #1 fires and then in the adjacent collector #3 fires and then back to the original collector for the #4 cylinder to fire. u get what im saying? being thats the runners are paired this way allows bigger turbos to be spooled up quicker using this design as its just more efficient ultimately causes theres not as much interference or turbulence i guess in the collector area like in a open design.
heres twin scroll mani i recently made for a neon with a big boy turbo........
oh and u will need to run twin gates.......... or u can run a single but u need to run tubing from each collector to a common w/g flange and keep them divided up till that point.
mike
mike
mike
K so it won't spool quick on a cobalt, but if I were to do the same as mike n throw it on my 2gn neon it would.. Doesn't seem to make sense how my $500 01 neon can get it to work, but a cobalt can't.. What would very late be in the rpm range?v
