Wondering which t3 turbo i need for my 2007, 2.2, auto
Hey everyone,
I am in the process of building me a turbo kit for my 2007 2.2 auto. I have been researching turbos and still not sure which one to get as i need something that is going to spool up quickly but still get to 300 hp once i build my motor. I need something that will start to spool at around 2500 or 3000 rpm. I would just like to get a turbo and hit the 200 hp mark after a tune. I know and heard of good things about the turbonetics t3 super 60 which is .48 a/r and 60 trim but it is very costly. It shows its good for 150 hp to 325 hp which would be about right. I was wondering which other garrett turbos would work for me in that hp range. Anyone to help would be greatly appreciated.
thanks
thanks
Hey everyone after browsing online i came across this turbo that is locally at a shop.
http://forcedinduction.net/cart/inde...products_id=57
Brand New M508 Street Series Head Unit
Perfect for engines 1.5L to 2.8L wanting to utilize the efficiency of the small compressor housing under low to mid boost conditions.
Features:
.50 A/R 3 inch Inlet 2 inch Outlet Compressor Cover
50.8mm Compressor Wheel Inducer
.63 A/R T3 Turbine Housing with STG I turbine and 5 bolt outlet with v band discharge
Wet Floating Dry Center
VSR Balanced
Supports 300+ HP
Internal wastegate actuated at 8 psi
Perfect for small engine tuner cars
Features:
VSR Balanced
Supports 300+ HP
I highly recommend using a T3/T4 with a 57 trim .63a/r they are the best matched for power and spool up on engines around 2.0-2.5L. We carry them at about $700/each. Its a full Garrett not a cheap Chinese knock off.
Hey everyone,
thanks
thanks
Same turbo on an SRT-4 made 348 to the tires on 15˝ psi.
Nearly the same size engine right?
Here are some pics of the same unit in the link. You can see the quality in it. True Garrett/Air Research centers and shaft. I know they are of quality.
I run two of them on a turbo Mustang and make over 700 to the tires. Also building a twin G35 with these units.
Great turbo for the money imo.
which unit?
good t-netics h3 unit is about 750 bucks which is what this is compared to..
here are the specs of the FI m508-2/garrett V1V2
Turbo is efficient to about 377 hp at 2.02 PR (15psi)
Info:
- 55.10mm V1/V2 Compressor Wheel (PN 20325)
- .50 A/R T04E Compressor Housing with 3in inlet and 2in outlet
- Standard shaft dry center oil cooled
- .63 A/R T3 turbine housing with stage II standard shaft
- Integral wastegate with dual port actuators set for 8psi and adjustable.
- 2˝ inch v-band turbine discharge
Map
Will be using a conservative tune on 42s. Hoping for around 220-250 hp so I don't blow something up.
which unit?
Info:
Map
Info:
Map
for some reason i was thinking that was a different turbo than the specs...my apologies....however...i do believe that a garret t3/t4 50 trim .63 housing and a clipped(stg3) wheel is of pretty close comparison to the above mentioned turbo, which can be picked up for 550-600 now adays depending on what options you pick, which still leaves another 2-250 dollars to put towards a bigger or better turbo
another option would be this one if desired boost is down low and room to grow is needed as well.
http://forcedinduction.net/cart/inde...products_id=66
Sep 28, 2015 12:51 PM
