Z54 or Z57
That happened between my first and second Z54. When the second one went on I was already planning to have the tune modified, but same tune that took first turbo to 25psi pegged the second at 30.
All that Dave modified was the WGDC real quick and it was back to being the same.
You should be looking at the LoRes sensor (that is the one in the charge pipe) as it can be viewed above 255kpa vs the intake manifold map sensor that is hard coded to max at 255kpa. Also don't forget to log the baro so you can subtract the baro from the LoRes sensor to get the boost pre throttle body
yeah I log baro for that reason!
Give a 10-15k review when you reach there as that's where many have seen the failures. Good to hear it is running strong though currently! Do you ever log with HPTuners?
You guys think I'll be ok on E47 with the Z54 on stock fueling system?
When PWerks tuned my second Z54 I had redone all the timing and added the fuel lobe cam since I was in there, and he said based on numbers he didn't think it would have been needed. Always good to have extra I guess, as I use the same setup for e blend on the Z57BB too.
I can't say 100% but I'd assume so, depending on how aggressive you want to go.
