this is it!
Old May 10, 2007 | 12:57 PM
Balt36's Avatar
this is it!
well boys...in about 30 min i will b starting the install of my sportlines wit my boy...wish me luck! any last words of advice beofr i begin?
Old May 10, 2007 | 12:58 PM
CCBalla10's Avatar
good luck man Post pics when you are done
CTORANGESC's Avatar
Good Luck, Hope you have all the right tools to make the job go by quick, Have Fun, Oh yeah pics are a must after you are done
Old May 10, 2007 | 12:59 PM
PlaysWitCars's Avatar
Former Cobalt Owner
good luck with the install!
Old May 10, 2007 | 01:01 PM
Jackalope's Avatar
Make sure you break the front upper strut bolt loose BEFORE you remove the strut from the car! The cars weight helps keep it from spinning in the mount.
IF however it does spin take a deep socket wrap it with electrical tape, grab it with vice grips and place it on the nut. Then run the torx bit "L" wrench down threw the center hole of the socket. Hold the "L" wrench still and turn the vice grips to break it loose.
The rears are cake.
Old May 10, 2007 | 01:03 PM
CTORANGESC's Avatar
I don't think they could have made changing the rear springs on the Balt any easier
