Able to cram a bigger engine under the hood?
You think its possible to shove a 2800 2.8L V6 (LP1) under the hood of the cobalt...
need more info on the motor look here http://www.gminsidenews.com/index.php?page=e_guide... telll me if u think its possible.
i guess if you wanted to have a sleeper...some guys do that **** for fun and then pull up to some poor sap in a little 4 banger with a turbo packed under the hood a blow em away with it. fun if you like playing mind games
it could be done but there'd be some major chopping done to the engine bay, not to mention the suspension would need major adjusting for the extra weight and the gear ratios would need to be changed to keep up with all the extra torque...a lot of work
Originally Posted by BullDog71ss
If you changed the cobalt to a v8 you'd want to change it to rwd or awd anyway. The stock tranny wouldnt work. Idl like to see an LS2 swap myself.
Originally Posted by BeastlyTA
The new Impala is fwd with the ls4, but I agree it should be rwd.
I don't think the 6 liter ls2 would fit in a cobalt without major modification to the firwall and engine compartment. That would be sick though. I'd have first gear run to 60 mph so you could launch the car having less wheel spin than if it were only to go to around 35.
patooyee
Oct 1, 2015 01:07 PM
