Air conditioning question
Old Mar 24, 2011 | 04:26 AM
Jeffs 06SS 2.4's Avatar
What is actually the ac on our cars. I thought the snow flake was but when i put it on circulate, it is very cold. I can tell a difference with the snow flake on. Also, when i put it on circulate, I can feel the compressor kick on, or thats what it feels like. Any one know what I am talking about? Thanks.
Old Mar 24, 2011 | 10:18 AM
TorqueSSter's Avatar
Lightbulb Well, I don't have the owner's manual in front of me ...
or, the car, as I am in the Camaro !
But, IIRC the button has to be pressed in to make the compressor kick in.
Not positive about that for Max A/C ( recirculate ) or Defrost.
The buttom I am referring to is the one on the LH side below & in between the the position selector knob ( face, feet, bi-level, defrost, yada yada yada ) & temp selector.
Hope this helps !
Britt
Old Mar 24, 2011 | 02:19 PM
CanadianCobalt's Avatar
A/C is a dehumidifier too, which is why it turns on when you hit circulate. It will also turn on when you put it to defrost or foot (the foot one is a GM button issue, the rest are normal).
It's normal, but the actual A/C button is the snowflake.
Joel
Old Mar 24, 2011 | 05:58 PM
Mine gets really cold without the snowflake, so I was wondering if I would save gas without the snowflake depressed. I think recirculate kick the compressor on though.
Old Mar 24, 2011 | 06:10 PM
06SS ALL DAY's Avatar
there is no way you will be able to tell the difference right now with the weather... stop fooling urself and wait till its a good 80 degrees out and not 40 lol. then try it without the snowflake button light illuminated... you'll see the difference.
Old Mar 24, 2011 | 08:38 PM
The day I did it was 82 degrees on monday in lincoln county. It was really cold. I didnt even turn on the snowflake until about maybe 30 minutes and thought it might have gotten a little colder but couldnt tell when i turned it off. If it was colder, it wasnt much.
Old Mar 24, 2011 | 08:55 PM
idk something dont sound right. lol hence the reason u created this thread. wish i could help ya
Old Mar 24, 2011 | 09:07 PM
Malaclypse's Avatar
When you turn on recirculattion, the A/C compressor kicks on because the car sees you're asking for the coldest air possible. This happens regardless of whether or not the A/C button is "on". Same thinfg for the defrost or foot positions.
You won't save any gas by using recirculate and leaving the A/C off. Its the same system. However recirculate mode will get the air much colder than just having the A/C on.
Old Mar 27, 2011 | 10:40 PM
LSJ's Avatar
LSJ
Joel
How is it an "issue"? Is it fixable?
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
