Anyone seen/used one of these
Old Dec 13, 2006 | 04:09 PM
HotWheelz's Avatar
A friend of mine has one of these and I wanted to find out if anyone on here has seen or used this type of pulley puller before. The site it is listed on says it is for Eaton Superchargers but only lists the ford lightning and cobra mustangs as vehicles it is used on. If nobody's used it, does anyone think it will work?
Old Dec 13, 2006 | 11:08 PM
Badmunky's Avatar
It might work.
The ting you need to find out is if it will remove the smaller pulleys that are used on the cobalts.
Later
Old Dec 13, 2006 | 11:26 PM
EthensCobalt's Avatar
agreed it might say eaton but for the larger pulleys....
just look up the name of it on the net and get specs
Old Dec 13, 2006 | 11:41 PM
Tofu's Avatar
Won't work. My friend had one included in his Kenne Bell kit for his 03 Cobra and I tried to use it when I had my pulley. Like everyone else said, it's for the larger diameter pulleys used on the M112. I think it worked on an M90 snout as well...but no luck for me.
Old Dec 13, 2006 | 11:57 PM
HotWheelz's Avatar
alrighty then, thanks. Just wanted to make sure before I tried it and srewed something up.
