better horn?
Old Jan 17, 2012 | 09:32 AM
RoadconeTuning's Avatar
better horn?
The cobalt has a pretty wimpy horn... have people been swaping them out for a better unit? i know the scoobaru guys have been doing this number with the hella superhorns or whatever they are called
Old Jan 17, 2012 | 09:34 AM
user 70823082's Avatar
MPx has this set up for the Cobalt....well, they have a universal set up.
http://www.modernperformance.com/hel...rn-p-2218.html
Old Jan 17, 2012 | 09:40 AM
znew's Avatar
you can always get these horns, they are a little cheaper than supertones
2X SUPER LOUD GRILLE MOUNT COMPACT ELECTRIC BLAST TONE HORN FOR 12V DUAL KIT | eBay
Old Jan 17, 2012 | 09:57 AM
I wonder how loud those actually are...
Old Jan 17, 2012 | 09:58 AM
StevoElSupremo's Avatar
its no hella supertone.. but I got the DualTone horn from a 2007CadillacSTS from a wrecker for $5, it sounds fantastic, much higher and sharper then that stupid ....road runner "meep meep" ....and it's pretty easy to wire up to
Old Jan 17, 2012 | 10:05 AM
WannaBFast5's Avatar
I have the hella supertones and love them.
Old Jan 17, 2012 | 11:57 AM
Rissa's Avatar
I have horns from a malibu, definitely A LOT louder and beefier sounding than the regular cobalt horn.
Old Jan 17, 2012 | 03:28 PM
HB_SS/TC's Avatar
Upgraded dual horns for the person above
Old Jan 17, 2012 | 03:31 PM
HB_SS/TC's Avatar
used to have this one too
New Horn for the Cobalt - YouTube
Old Jan 17, 2012 | 07:42 PM
Probably the same as the caddillac.. sound nice eh?
Old Jan 17, 2012 | 07:58 PM
TommyP's Avatar
AWD > FWD
I need to get some super tones for my car. You think cobalt horns are bad, mine are laughable
Old Jan 17, 2012 | 08:37 PM
well yeha^ thats a japanese car though, most of them are barely audible lmfao
Old Jan 17, 2012 | 09:21 PM
HB_SS/TC's Avatar
mitsu horns are the most embarassing
I put them on mine
Old Jan 17, 2012 | 10:28 PM
FryLoch's Avatar
Why not find a junk yard horn from a 1500 or Sierra or Tahoe etc etc
Old Jan 17, 2012 | 10:39 PM
LS6Rally's Avatar
someone on here also used one from a Newer Monte Carlo, and they said it sounded much better.
Old Jan 18, 2012 | 01:05 PM
sponge14's Avatar
Train Horns & Train Horn Kits: Loudest Horns Available
Old Jan 18, 2012 | 01:10 PM
Can you post a video of how loud they are?
Old Nov 1, 2012 | 01:04 PM
how did you mount them?
Old Nov 1, 2012 | 05:00 PM
casionerd's Avatar
village idiot
This is an old thread so you may not get a response from the guy you asked. Here's how I did mine:
I bought some aluminum strips that were bent at 90 degrees from Lowe's or Home Depot. Can't remember. I wanted to hook the horns up to the two bolts holding on the hood latch thing. I cut one side of the aluminum and bent it about 45 degrees. Then I drilled a hole through the overlapping pieces and held them together with a rivet. Then I measured the location of the next bend by seeing where the horn would not rub the grill or radiator. I then made the cut and bend and rivetted it together. This doesn't have to be exact. You can eyeball it because you can move the bracket up or down on the bolt you're gonna use to hold it down. After you get your bracket the way you want it, drill holes for mounting it to the hood latch and to mount the horn to the bracket. Bolt it up and bend it and so forth so that you get it just the way you want it. Then remove the bracket and make an exact copy of it but in reverse.
When you wire it up, you can tap directly into your existing horn harness. If you use the regular horn wiring it'll be fairly loud and much louder than the OEM horn. If you hook it up the way the instructions say to, it'll be really loud.
Old Nov 4, 2012 | 01:20 PM
nice, i didnt think about that. I'll have to check out lowes/home depot.
Old Nov 4, 2012 | 01:37 PM
Aleksey's Avatar
how often do you guys use your horns lol
Old Nov 4, 2012 | 06:44 PM
casionerd's Avatar
village idiot
I honk my horns all the time. If you get Supertones, you'll be a honkie just like me. I bet I've honked three times today.
Flock of birds on powerlines near the road? Honk. If you can get a couple to fly away, the rest will usually follow. This is a victory and can be celebrated with a few quick beeps.
Another Cobalt? Beep. Beep. Followed by WUHN. (what's up head nod)
Hot chick walking, riding a bike, pumping gas, jogging, etc.? Beep.
Someone won't turn right on red when it's clear? Beep.
Car next to you has their gas cap door open or a low tire? Beep. Beep. Followed by hand communication between two people who aren't deaf and/or yelling out windows. After the reason for the honk is understood, there is usually an emphasized big mouthed "Thank You" followed by a wave and then a turn signal to indicate they're gonna check out whatever it is.
The car next to you is using the street lights to drive and doesn't have their lights on after dark? Beep. Beep. Then pretty much the same as the gas cap/flat tire thing.
Truck with a bunch of crap in the back lost something or is about to lose something? Beep. Beep. Communication.
Light turns green and the car in front of you hasn't noticed after three seconds or so? Beep. If you're a couple cars back from the front, it's okay to lay on the horn. Like BEEEEEPPPPP!!! This is because the car getting honked at has no idea who's doing it. Every once in a while you'll be lucky enough to see the guy who wouldn't take off get mad at the car that was directly behind him and in front of you because he thought they were the ones honking at him.
Driving by the golf course? Anyone that looks like they're on their downswing or about to putt. Beep.
Car almost merges or changes lanes into you? Beeeeeeepppppp!!!!
You're in a driveway and someone in that house was supposed to come out that door and get in your car five seconds ago? Beeeeepppp! This is more acceptable if it is extremely hot or cold outside... or it's raining.
You're going under a bridge or through a tunnel? Beeeeeeepppppp!!! Beeeeeeeppppp!!!! Amplified echoish type sound.
Some random guy preaching on the corner? Beep. Guaranteed he will wave at you. You totally just interacted with another human being at the push of a button.
Cows? Beep.
People holding some sort of "Vote for this guy" sign. Beep. Beep. Again, you will get waves. They will think they are actually making a difference and you will smile. Think of it as giving that bum on the corner some change except you're not spending any money.
Group of geese, pigeons, etc. congregating in a parking lot, along the side of the road? Honk!
Dog or other animal ahead that looks like it MIGHT walk into the road ahead of you? Beep!
Kids playing in or near the street? Beep. I especially like this one because even if the kids are playing in a driveway or on the sidewalk or they get out of the way when they see me coming, if I honk they sometimes get in trouble anyway.
Missed your exit? Hit the steering wheel and then maybe follow up with a Beep.
Almost hit an animal in the road? Honk. This works even if the animal is behind you, but it needs to be immediately after you almost hit it.
You're listening to the game on the radio. It's close and your team just scored with 15 seconds to go? Beep. Beep. Beep. Beep. Beep.
You drop someone off at their house and they walk in front of your car? Beep.
You see someone you know in their car, in a parking lot or at their house? Beep. Beep. This works even if you're just driving by their house.
Someone stops at the end of a merge lane right before it goes onto the highway? Hooooonnnnkkkkk!!!
And, of course, there is the roll race. It usually goes something like this:
Beep..................Beep..Beep.
Old Nov 4, 2012 | 06:55 PM
dakotaspeir's Avatar
#cobalthoes
Light turns green and the car in front of me hasn't noticed after three seconds or so? Beep. If you're a couple cars back from the front, it's okay to lay on the horn. Like BEEEEEPPPPP!!! This is because the car getting honked at has no idea who's doing it.
Golf course by my house. Anyone that looks like they're on their downswing or about to putt. Beep.
Cows? Beep.
People holding some sort of "Vote for this guy" sign. Beep. Beep. Again. You will get waves. They will think they are actually making a difference. Think of it as giving that bum on the corner some change except you're not spending any money.
That pretty much summed up every example I could think of haha
Old Nov 4, 2012 | 07:01 PM
nhanson's Avatar
Any newer impala, G6, monte carlo have "regular" sounding horns that plug and play
Old Nov 4, 2012 | 08:55 PM
Haven07's Avatar
Casionerd....how could you forget the clueless pedestrian crossing the street with out looking both ways and is texting on their phone? That's a definite honk there
Edit: The horns weren't exactly what I thought they would be, I was hoping more for a thundering boom like from a semi
