Boost Poll
Old Aug 21, 2005 | 11:03 AM
xavier102772's Avatar
Boost Poll
Just out of curiosity:
How much boost(psi or kpa) are you pulling and how many miles/km's are on your car?
I'm at 80kpa(~11.5psi) and 1463km(~900mi)
Old Aug 21, 2005 | 12:33 PM
chevytech329's Avatar
12.5-13.0 psi @2600 miles.
Also.. no problems what so ever!! (keeping fingers crossed)
Jeff
SS/SC
Victory red with red inserts, sunroof
Old Aug 21, 2005 | 12:36 PM
RAZOREXPRESS's Avatar
13 Psi (6800 Miles)
Old Aug 21, 2005 | 01:55 PM
b-spot's Avatar
70 kPa, 8000km's
Old Aug 21, 2005 | 02:01 PM
Jmc007's Avatar
Mine is 81 KPa and 900 miles done. Hey b-spot I think you should go to the dealer to ajust the screw on the by-pass valve to get your 12 PSI boost.
Old Aug 21, 2005 | 02:10 PM
bmoreyellowss's Avatar
13psi (6040miles)
Old Aug 21, 2005 | 03:06 PM
silverSS's Avatar
12-13psi with 3400miles
Old Aug 22, 2005 | 12:11 AM
I felt a little bad that I was only getting 80kpa, but I really feal sorry for b-spot at 70. Anyway, I'll give mine another couple thousand km's and if it still isn't up to 88kpa(~12.5psi), then I'm taking it in to get it checked out.
Old Aug 22, 2005 | 12:21 AM
ExHondaMan's Avatar
Domestics Pwn
2800miles... only seeing 10.5 on the gauge... I dont believe it to be correct...
Bone stock the car is putting down 216hp and 195trq.... thats pretty on target with everyone else .. even thoughs who are seeing 11-12.5psi on the gauge !
Old Aug 22, 2005 | 01:02 AM
l337m4573rpyr0's Avatar
gauge only shows 10-11psi. only 2300 miles so far though.
Old Aug 22, 2005 | 03:04 PM
mchat's Avatar
Don't trust the stock boost guage.
Old Aug 22, 2005 | 03:14 PM
plyboy-illest's Avatar
80 kp and 2000 KM
Old Aug 22, 2005 | 04:04 PM
MarcS's Avatar
The Stig
Anyone else only getting about 6psi in first?
Old Aug 22, 2005 | 04:16 PM
Mikecobalt's Avatar
i'm getting a little bit more than 90 kpa and 6000km but like a guy said, don't trust the gage too much
Old Aug 22, 2005 | 07:13 PM
On a bit of a side note, about how much is it to get a dyno done? I'd really like to know if my gauge is out or not. Thanks.
Old Aug 22, 2005 | 07:32 PM
codyss's Avatar
When it's 80 degrees or higher I see 10-10.5psi and at less than 80 degrees usually 11-11.5psi.
Old Aug 22, 2005 | 07:59 PM
Jase's Avatar
Originally Posted by b-spot
70 kPa, 8000km's
dude.. that cant be right
ive seen mine as high (as i can test so far) at 80ish kpa at 8400 kms
im sure it will go higher its just really fast at that speed
Old Aug 23, 2005 | 12:21 AM
ssc's Avatar
ssc
boost
i got 7500km and i hit 90kpa
Old Aug 23, 2005 | 01:38 PM
Mercury's Avatar
10 psi at 1100 miles
Old Aug 23, 2005 | 05:42 PM
97cavie24ls's Avatar
s/c i test drove had 7 miles , and hit 11-12 psi
Old Aug 23, 2005 | 07:54 PM
GeoChevyCobalt's Avatar
At max WOT I am getting 12.5psi. Befor I move my vacum line I was getting 11psi max
Old Sep 28, 2005 | 08:00 PM
Calgden's Avatar
I hadn't really paid much attention to my boost guage until I read this while reading through some of the old threads. The most I have seen from my guage is 60 kpa. I also notice that whenever idling, it reads -50 kpa. Does this sound normal to all of you?
Old Sep 28, 2005 | 08:16 PM
05_Blue_B10WN_SS's Avatar
I'm getting about 11 PSI right now, with 1,700 Miles. Though i dont get on it much, maybe a little higher.
Old Sep 29, 2005 | 02:55 AM
OniMirage's Avatar
12~12.5 at 3200 ~ miles
Old Sep 29, 2005 | 08:00 AM
R33P3R007's Avatar
360 L337 User
Same, 3800
