Bumper Removal
Old Oct 13, 2008 | 09:34 PM
Sizzle06's Avatar
Bumper Removal
I know in the how to it says to remove headlights but is there another way to remove the bumper without taking them off?,thanks.
Old Oct 13, 2008 | 09:36 PM
07cobalt4life's Avatar
ummm nope i dont believe since u need to take the headlights off to get to the bolts so
Old Oct 13, 2008 | 09:37 PM
cobaltmatt23's Avatar
i am positive there is a thread about this
Old Oct 13, 2008 | 09:40 PM
Sizzle06's Avatar
Just wanted to know because i'm installing my heat exchanger tomorrow.
Old Oct 13, 2008 | 09:44 PM
jefferyss's Avatar
yuo dont need to , un-due the fender liners bolts , there is 3 10mm bolts in each corner of the bumper where it meets / ties into the fenders.take those out .4 clips along the top of the grille. 1 plastic screw on the underside of the lwr grille opeing going upward into the reinforcemnt on either side of the license plate area( i beleave they are a robertson screw( square) and made of plastic ) and you also have to un-do the fender liners on the undersiade of the bumper in each corner.
you do not have to take the headlights off at all.you can but you dont need to. if you havent taken it off beforei would suggest pulling them out to see where the bumper / fender bolts are but its not needed....
p.s. don't forget to un plug foglights lol
good luck
Old Oct 13, 2008 | 09:47 PM
Sizzle06's Avatar
Thanks.Has anybody installed there H/E with the bumber on?
Old Oct 13, 2008 | 09:50 PM
jefferyss's Avatar
when i did my cx , i had to modify the bumper reinforcment...damn near impossible to mount with out taking bumper off
if you want to drive up here to canada , i'll install it for you for free lol
Old Oct 13, 2008 | 10:46 PM
Sizzle06's Avatar
How much difference is the cx h/e to the zzp h/e?
Old Oct 14, 2008 | 12:11 AM
HunterKiller89's Avatar
the ZZP is i BELIEVE in between the small CX and the large CX HE in terms of square inches
Old Oct 14, 2008 | 12:41 AM
Sizzle06's Avatar
I thought i had seen a post wear someone installed the zzp h/e without removing the bumper.
Old Oct 14, 2008 | 05:58 PM
good luck
the only way to reach the bolded is by removing the headlights or by removing the fender liners, and if you do so by removing the fender liners, its almost impossible t reach the top bolt of the three
Delta coupe
Sep 30, 2015 08:11 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
Cptnslo
Sep 24, 2015 09:32 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Albertsstc09
Sep 16, 2015 08:18 AM
