View Poll Results: Does a FWD Slide sideways when burning out, the same way a RWD car does?
Voters: 44. You may not vote on this poll
Burning Out!!!! Who Knows Their Physics?!?!?!?
OK so after going to court over an "Unsafe Start" Issue a couple months ago, and have wondered and decided to ask the people that know best, the ones driving their cars.
When at a stop, in a Front wheel drive car, if you begin burning out, will the car act as a Rear Wheel Drive car would and begin sliding sideways?!?!
well i personally dont think that happens in Front wheel drive, i know it does in Rear wheel, but according to the police officer and judge that were involved in my case, Front wheel drive cars slide sideways when burning out.
I APPRECIATE ANY FEEDBACK.... THANKS LADYS & GENTS
can what begin to slide sideways. because yes the front can, If both tires are spinning the front is not going to stay still, the car moves forward, but it also moves sideways. my car almost always moves to the passanger side.
go outfront and do a kiler burnout. check what the lines look like, and you will see that the car moved sideways as well as foreward.
All depends on if BOTH front wheels are spinning. Even in a RWD car if only 1 wheel spins it will not make a mark in the letter "J" Only POSI or a locker that allows both rear wheels to recieve = amounts of torque will make the "JJ" burn out marks.
So the answer to your question is it all depends on how the FWD car is equiped.
Originally Posted by Jabbles
I think if you have an LSD it can slide sideways.
I had to choose it does, but it's really that it CAN. I have had my font end slide to one side when nailing a 4-2 shift @ 40 on a wet road, it actually slid a supprising ammount. This is not to say that it happens every time or is even likely, just that it can happen.
I was about to race this guy a couple years ago in my VW, he had a Jetta. When he launched he spun them and his car came within a hair of hitting mine because he was sliding sideways.
Basically it has a lot to do with torque steer and since you aren't movnig fowards, you're moving to the side.
Everybody here has got the right idea. The answer is: IT DEPENDS.
On an open differential, you can spin one tire while the other doesn't turn. So the car will have three tires with traction, and hence keep going straight
On an LSD, if you get both tires spinning, then yes, the car could creep to the side.
On a skid, which is a totally different thing, FWD cars go straight ahead. RWD cars fishtail.
open diff, it should
on our cars the right tire is the drive tire, so if both wheels are spinning unequally, it will move side to side
do a burnout with your hands off the wheel, and see what direction it goes
Its similar to driving on snow. I live in the snow belt by cleveland.
When the tires start to spin the car usually will drift to one side or the other, and if the tires continue to spin the car will go in a stright line but even if you turn the wheel, the car will continue to go the same direction.
LSD will help by putting power more evenly to both wheels. This definatly helped in my 2 wheel drive pickup, always launched stright unless I turned the wheel, even though sometimes it just sat there a few seconds.
RedCavyRS99
Oct 20, 2004 01:45 PM
