Cam sensor code
Old Aug 7, 2017 | 02:45 AM
blackbear10's Avatar
Cam sensor code
I have a 06 2.2 cobalt with cps code. changed plugs twice coil pack 3 times as well the ignition module. What else can it be? I am lately getting the fuel trim code also. changed injectors and fuel pressure is at 75psi. Any ideas?
Old Aug 7, 2017 | 03:29 AM
Sharkey's Avatar
fuel pressure is at 75psi? thats a problem. your fuel pressure should be 58psi (give or take a couple) at the rail at all times. if its 75psi you might have a restricted fuel filter or the regulator in the fuel tank is stuck.
whats the code for the cps?
Old Aug 7, 2017 | 03:33 AM
341 if I remember correctly. Book calls for 70psi
