Can't remember what I have.
Old Aug 8, 2008 | 03:24 PM
cobalt143's Avatar
Well, whether it read accurate or not, it says around 15-17psi...with K&N intake, catless custom exhaust and stage 2 pulley. A guy I met down in Orlando had just an intake & stage 2 (i think), and had about 14psi...so...all of them must be wrong then.
Old Aug 8, 2008 | 05:02 PM
theneelster's Avatar
Intake doesn't increase boost.
Exhaust decreases boost (well mainly header/dp).
So while 14psi is reasonable with stage 2, I'd say 15-17 with just the stage 2 pulley means a bunk boost gauge.
You can lose 1-2 psi with a better flowing header/dp...especially the vibrant one. Not that it matters, boost doesn't equal power.
Old Aug 8, 2008 | 05:18 PM
cobalt143's Avatar
Well, then lets find out how many people's are wrong. Go run your car see what boost you push.
Old Aug 8, 2008 | 05:31 PM
rukkee's Avatar
Originally Posted by D4u2s0t
yes. but just because the boost is lower doesn't mean it's bad, or making less power. the engine will run more efficiently.
Exactly , i'd love for my car to have a 2.5'' pulley only making 10psi . That would just mean i have a more efficient air pump
Old Aug 8, 2008 | 11:32 PM
cobalt143's Avatar
Well, I will have to say my car was always sick...don't know if anyone else has had this happen when they had their cobalt stock, but i have blown the oil dipstick off twice when I was still stock.
Old Aug 8, 2008 | 11:54 PM
Usually 14 pounds with a 2.9 and head/dp.
Old Aug 9, 2008 | 12:03 AM
rukkee's Avatar
There are too many variables to get a poll of PSI numbers from different members. Air temp , humidity and elevation above sea level will play havoc with the numbers.
Old Aug 9, 2008 | 12:40 AM
ecotecon18s's Avatar
bad intake manifold gasket...you must have an 07...
my buddy works as a tech at Bill Heard Chevy; ive heard about it a hundred times.
Old Aug 9, 2008 | 11:39 AM
cobalt143's Avatar
The dip stick was just loose...is all that is. It isn't doing it anymore. But since that has happen, I have oil grease all over the engine bay, what is the best product to get that S**t up?
Old Aug 9, 2008 | 10:41 PM
cobalt143's Avatar
Very important!! When any of you guys' cobalt's are at idle, and you open your hood, does the car make a fluttering sound? Supercharged Cobalts only please. Right now my car is making fluttering noises when idle, and I don't think it did it before, so I need to know.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
ThoR294
Oct 4, 2015 08:44 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 30, 2015 07:22 AM
