Car is dead. Help!
Old May 24, 2020 | 10:03 AM
Giggleschits's Avatar
Car is dead. Help!
So Friday and Saturday I replaced my Transmission, Clutch, Flywheel, Wheel Hub Assembly’s, and shifter. The car had been sitting for about 5 months by this point. Took it on a test drive and it ran really well but I had quite a few warning lights. Battery light, ABS, Brake, CEL, TPS. When I looked at the codes it’s just the normal MAP issues with my tune etc that I’m always dealing with but nothing else. On the way home I lost all power and the car died. Do you think it is just a bad battery from sitting for so long or did my alternator take a crap or is it possible I missed a ground somewhere?? Any ideas? 2009 Cobalt SS
Old May 25, 2020 | 04:48 AM
blu3_v1p3r's Avatar
It could very well be a bad ground either not connected or not making good contact. Checking the grounds should be the starting point. You probably had to disconnect wiring to drop the trans for the clutch. If you can't find something not connected or not tight, you can get your alternator tested to check and see if that is your issue. A bad BCM is known to cause warning lights and make the car act crazy, but I feel that's not very common. My thought is alternator ground wire. Also I recommend getting the battery charged or a new battery if you need one.
Old May 25, 2020 | 02:29 PM
I got the battery charged so I’ll get it up in ramps today. The only ground I remember taking off would have been on the starter I think other than wires that were plug in. Would that affect the charge to the battery somehow?
Old May 25, 2020 | 05:57 PM
Turns out it was the wires to the starter. I had the black wire coming from the left of the starter in the bottom. Not the top. Switched that and whalla. Runs like a crappy champ it is now
Kodi Rudman
Jan 11, 2018 08:15 AM
Jesse29
Nov 1, 2017 10:17 PM
jp1600
Dec 14, 2012 08:18 PM
Owen S
Mar 9, 2012 12:20 AM
