Change the AC Compressor Clutch
Old Jul 28, 2021 | 08:22 PM
SGJ12's Avatar
Hello,
Has someone experience to change the ac compressor clutch of a 2008 Chevy Cobalt LS? Is this possible without removing the whole ac compressor?
Thanks in advance.
Old Aug 7, 2021 | 12:16 PM
primem's Avatar
you can change just the clutch. the a/c system will have to be discharged and the compressor removed from the vehicle. you will need a 3 jaw puller, snap ring pliers and an impact gun to remove the clutch plate nut or a tool to hold the hub assembly so you can remove the clutch plate nut with a ratchet.
not sure what is jammed up with your assembly....make sure the compressor shaft rotates by hand. If its seized or and metal is seen in the pag oil....the comp is f'ed replace it and the condenser/reciever drier.
klotzy_550
Aug 19, 2016 01:33 PM
Chaos_Six
Jul 9, 2014 07:48 PM
Jazzy SS
Jun 9, 2011 10:57 PM
RedEcotecSS
Apr 17, 2009 04:55 PM
Element291
Aug 14, 2008 02:56 PM
