Cobalt mods
Cobalt mods
OK guys here we go.... I've got a '09 SS that I purchased a little over a year ago. The mods done are as follows. It has a Hahn Race craft cold air intake along with intercooler and piping. Also, a Hahn exhaust with electronic cutouts. Car currently puts out 25 lbs of boost. Anybody have any idea what kind of power it puts out? Never had it on a dyno and was curious if anyone has a similar set up.
Honestly it's all in the tune and how aggressive they went with it. It could be 300whp to about 320 as measured on a dynojet, depending on who tuned it.
I know that it builds 25 lbs of boost from 1800 rpm and holds it until 6500 rpm with no bleed off. I've surprised a lot of new Mustang and Camaro owners with it. I'd like to get it on a dyno and see what it does. Well thanks for your help. I appreciate it. This is the first turbo I've owned. Always been a rear wheel v8 owner.
You should have mentioned it to begin with cause the turbo makes a big difference. It's probably got a s20g on it if it was done over a year ago. I would have to guess it's closer to 400whp instead of 305.
I'm sure it runs good, and traction is an issue the higher you go in hp. Trans mounts and control arm bushings help as do good sticky tires but they are expensive. What color is the car?
