View Poll Results: Malibu SS vs Malibu Maxx SS vs Cobalt SS/NA
Malibu SS
26.32%
Malibu Maxx SS
12.28%
Cobalt SS/NA 2.4L
35
61.40%
Voters: 57. You may not vote on this poll
Cobalt SS/NA vs Malibu SS
Old May 14, 2007 | 09:57 AM
SilverSurfer's Avatar
the malibu may have the slightest of edges in speed, but according to the handling tests ive seen the cobalt wins across the board. i like the malibu though.
Old May 14, 2007 | 10:56 AM
blackngold20's Avatar
Originally Posted by shawn672
Not sure where you got your numbers from but here they are:
Malibu SS: 3,476 Pounds
Cobalt SS Sedan: 3216 Pounds
260lbs difference
Now lets say you added GMPP Intake, Cat-back Exhaust, and Exhaust Manifold...you might be able to pump out close to 200hp.
So:
Malibu with 240hp
or
Cobalt SS with 200hp and weighs 260lbs less
Will the weight difference make up for the difference in power? Malibu has the V6 vs the little 4-banger.
Tough decision...
edit: According to Dragtimes.com the Malibu SS gets about 15.310 seconds @ 91.020mph. While the Cobalt SS 2.4 gets about 15.5-15.6 seconds at around 90mph.
Doesn't seem to be much difference really...I guess I'll still try and get the Cobalt then..just looking for the next best alternative.
Thats because I was basing the weight of the balt from a 2 door not sedan
Old May 14, 2007 | 11:22 AM
shawn672's Avatar
My fault, should have been more clear.
Comparing the automatic trans, 4 door versions of all vehicles.
Old May 14, 2007 | 05:03 PM
sushidog's Avatar
If you're considering the Malibu because it's roomier, consider the 303hp Impala SS.
Sure it's a little more money, but in my opinion is a much nicer car.
It deliveres virtually identical epa mileage numbers to the Malibu SS. The v8 Impala actually delivers 1mpg higher highway mpg than the v6 Malibu.
Not only will it run circles around the Malibu, but you get much more space for the family.
Old May 14, 2007 | 05:44 PM
ItalianJoe1's Avatar
Have you driven them both back to back? The Impala feels a lot heavier, and if you think you know anything about torque steer, the Impala will teach you the true meaning of it. Hit the gas at low speeds and it changes lanes for you. Its cool, but not in traffic
The malibu feels stiffer and better handling, more along the lines of comparing an SS/SC cobalt to a regular SS. Just drive them both before making a decision based solely on the specs. Remember, 323 lb of torque should not be put down through the front wheels.
Old May 14, 2007 | 05:49 PM
shawn672's Avatar
The age old question, why is RWD better then FWD???
Old May 14, 2007 | 06:23 PM
is the Impala SS RWD or FWD? I thought it was rear?
Old May 14, 2007 | 06:50 PM
FWD buddy. It sucks ***** in such a powerful car to not be able to use it. Open Diff, really shitty traction control that can't be totally disabled unless you are in L, and a foot activated e-brake. They really did thier best to make the Impala/Monte Carlo SS not fun to drive. Its quick and powerful, but nowhere near as much fun as the Malibu SS, which i probably .05% as fun as an SS/SC.
Ok, maybe that last line is a litte biased
Weight balance, traction, turning, there is quite a list. The SS Impala fails in all these categories. Its the same 5.3 V8 out of the trucks, but stuffed sideways between the front wheels. If they really wanted to do that, they shoulda used the northstar engine, similar HP with a much more FWD friendly torque curve.
FYI, they redesigned the drivetrain in the 2007 Impala/Monte SS, adding "equal stiffness" axles to help combat the torque steer. Yet they won't address the wheel-hop in the Cobalt. Does that give you an idea of how bad it is? GM also changed the composition of the motor mounts and the design of the cradle slightly I think, but don't quote me on that part.
Last edited by ItalianJoe1; May 14, 2007 at 06:50 PM. Reason: Automerged Doublepost
Old May 14, 2007 | 06:52 PM
chevysalesman614's Avatar
I voted for the Malibu SS. they look pretty nice IMO. and have alot of nice features that the SS cobalts do not have. but, they are more expensive.
Old May 14, 2007 | 06:54 PM
Yeah, fully loaded an SS Malibu is around 27K, the Impala around 30-31K. The malibu is availible with rear-seat DVD, which is pretty cool though.
Old May 14, 2007 | 08:47 PM
  #36
RaineMan's Avatar
I looked pretty hard at a black Malibu Maxx SS they had in the showroom when I went to get my SS/SC... they were close to the same price. The Malibu isn't gonna have any aftermarket support though... and they aren't that fast.
dennis69
Oct 20, 2015 04:49 PM
Rayray2781@gmail.com
Sep 20, 2015 01:52 PM
shawnsseries
Sep 10, 2015 08:29 PM
ROADKONE
Sep 9, 2015 02:32 PM
