control arm bushing question
Old Sep 3, 2013 | 09:29 PM
LNFTX's Avatar
Has anyone Pressed their own control arm bushings???
I'm wondering about the front (leading) c.a.b. When you press it back in would you press against the metal mount with the bolt holes or press against the rubber bushing itself
Btw stock bushing could not afford proper Powell bushings
Old Sep 3, 2013 | 09:55 PM
Powell Race Parts's Avatar
if you can replace that bushing you are a good man. I cant. I Without making a fancy tool like a piston ring compressor only smaller and stronger, to compress the rubber so the bushing can be installed. Good luck, let us know how it turns out. I have failed and just dont bother. Buy a new arm.....
Old Sep 3, 2013 | 09:58 PM
blueLNFftw's Avatar
You have to press it around the metal sleeve. Youll have to find something that is the same diameter as the bushing sleeve. Line it up and use a shop press to push it out. Freeze the new ones and install them cold the same way.
Old Sep 3, 2013 | 09:59 PM
buildmeanempire's Avatar
^ That. I just used a big ass socket.
Sent from my Nokia 3100 using CobaltSS
Old Sep 3, 2013 | 10:03 PM
LNFTX's Avatar
Front one doesn't have a metal sleeve
Old Sep 3, 2013 | 10:06 PM
LNFTX's Avatar
Thank you sir not what I wanted to hear but good to know may not change that one then don't know if its bad just throwing parts at a low speed clunk somewhere up front that can't visually find
Old Sep 3, 2013 | 11:34 PM
you are right, the front does not have a metal sleeve. my guess clunks dont come from that bushing except in extreme cases.
try.
trailing cab for sure. torque for bolt is 145 ft lbs.
swaybar end links
strut bearings.
if an older cobalt try sway bar single bolt bracket loose.
if a newer cobalt 08-10 try sway bar moving side to side and end link hitting arm; note that LS/LT cars 08 up may still have the single bolt bracket 22 mm front sway bar. I am not sure.
Old Sep 3, 2013 | 11:39 PM
LNFTX's Avatar
^^this guy is a class act
I couldn't afford your parts but I still get good professional advice thanks again
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Extremespeed
Sep 29, 2015 04:34 AM
Coballin13
Sep 25, 2015 08:43 AM
