couple newby questions
ok i just picked up an 06 cobalt ss/sc. i just have a couple questions about it. the breakdown that the dealer showed me said that it has heated seats. the button for the heated seats isn't where it should be(by the airbag display). would it be somewhere else? also i have the recaro seats, did those still come with heated seats?
and then my second set of questions is, the "up-shift" light doesn't come on at anytime when i am driving? do i have to do anything special to turn it on? sorry for all of these questions but like i said the car is new to me so i am still trying to figure it out. thanks for all the help.
if you give us the vin one of us should be able to look up the options list for ya but no as far as i know factory heated seat switches were by the hvac controls. and the up-shift light many people have been having issues with this and basically have come to the conclusion of it it comes on great if not oh well lol.
The upshift light on the SS S/C is for Stage 3 to indicate high-octane mode, so it's disabled normally (you don't really need it, stock shift point is just before redline anyway). I don't know about the heated seats... shoot the VIN out to the thread and someone will run it.
I dont think the recaros come with the heated seats. If they do have it, it would be under the radio. like an egg shaped switch. I just stopped listening to my dealer, they didnt know what a supercharger was....
wow you guys are fast. here is the vin 1G1AP14P767789320. also one other question, if i have the recaro seats i also have the limited slip correct?
[QUOTE=06cobalt racer;2113718]wow you guys are fast. here is the vin 1G1AP14P767789320. also one other question, if i have the recaro seats i also have the limited slip correct?[/QUOT
yes.
yes.
yes you should have heated seats according to the build sheet
VIN 1G1AP14P767789320
VEHICLE BUILD
Merchandising Model : 1AP37 -2006 COBALT SS SUPERCHARGED COUPE
Gross Vehicle Weight Rating : 1762 kg (3885 lb) Order Number : JVBNTP
Build Date : 02/15/2006 Build Plant : 167A
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
ALV - SENSOR INDICATOR
ASF - AIRBAGS, SIDE HEAD-CURTAIN
CF5 - ELECTRIC SUNROOF W/MAP LIGHTS
C67 - ELECT. FRONT AIR CONDITIONER
DG7 - BODY COLOR POWER MIRRORS
DT4 - ASHTRAY AND LIGHTER
FE5 - SUSPENSION
FE9 - 50-STATE EMISSIONS
FQ7 - 4.05 FINAL DRIVE TRANSAXLE RATIO
G85 - PERFORMANCE PACKAGE INCLUDES: *RECARO FRONT BUCKET SEATS *LIMITED SLIP DIFFERENTIAL
IP4 - TRIM INTERIOR DESIGN - AR9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K09 - 120 AMP GENERATOR
LOD - ASSEMBLY PLANT - LORDSTOWN,OHIO
LSJ - 2.0L DOHC SUPERCHARGED 4 CYL
MM5 - 5 SPEED MANUAL TRANS W/SHORT THROW SHIFTER
MU3 - MANUAL 5 SPEED TRANSMISSION
NP5 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT
NW5 - 18" ALUMINUM WHEELS
QTJ - P215/45R18 BW TIRE
RE8 - UPGRADE ORNAMENTATION
R6P - PREMIUM PAINT
R8K - *******************************
R9N - HEATED LEATHER APPOINTED FRONT BUCKET SEATS
SLM - STOCK ORDERS
UQ3 - PIONEER 7 SPKR AMPLIFIED SYSTEM
US8 - AM/FM STEREO W/CD & MP3 (REPLACES STD/OPT RADIO)
U2K - XM SATELLITE RADIO-SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
VK3 - FRONT LICENSE PLATE MOUNT
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
W2E - RICARO SEATS
1SZ - OPTION PACKAGE DISCOUNT
19I - EBONY
194 - EBONY WITH EBONY INSERTS
2SS - 2SS BASE SUPERCHARGED COUPE PKG
6AJ - FRONT SPRING
7AJ - FRONT SPRING
74U - VICTORY RED
8AC - REAR SPRING
9AC - REAR SPRING
VEHICLE BUILD
OPTION CODES
FE5 - SUSPENSION
R6P - PREMIUM PAINT
SLM - STOCK ORDERS
W2E - RICARO SEATS
19I - EBONY
6AJ - FRONT SPRING
7AJ - FRONT SPRING
74U - VICTORY RED
8AC - REAR SPRING
9AC - REAR SPRING
thats nice but the recaro's are not heated, i understand thats what the build sheet says, but GM build sheets are known to have minor flaws
obviously the build sheets can have flaws which is why the only way to be sure is to double check the window sticker or the little silver sticker under the trunk's carpet and look for the code that says if he has heated seats or not.
Condescending means acting in a superior or holier-than-thou manner toward someone.
Contradicting means (in this case) two sets of information that are both supposedly correct, but are in direct opposition to each other.
And I have G85 w/heated seats in my '07. It's possible on an '07 (dunno about the '06 models) to have regular seats and the LSD.
I had after market heated seats put in my car at the dealer when I bought my cobalt, the switch for mine is on the door side of each seat in the front of the plastic part just below the fabric (I had heat put in the cloth seats because I have a dog and didn't want ruined leather seats in my car) maybe you have after market heaters?
