Does any one know.....
www.tirerack.com input the vehical and view the stock tire you should be able to locate the specs chart and appropriate size. Just a quick bit of info the first number on every passanger tire is the tread width in millimeters. The second number is the sidewall height as a percentage of the tread width. The third number is the wheel diameter the tire is designed for.
